Question about Oster 6295 Toaster Oven with Convection Cooking
Intermittently won't come on, now fails to work at all.
Can't seem to get it apart to check for bad switch. cover still at attached at top in front even when screws are removed. Problem appears to be in the timer/on switch. Oster toaster oven model 6295. Is it wotrth repairing?
    Scholar:
  • 53 Answers
Your timer switch is going bad and will soon stop working alltogether. If the switch is a model DKJ/1-60 you will not find one, however, there is a switch made for Delonghi that will work. Go to The Gourmet Depot website and look for switch part # 05XDE5218104600. If you have a different switch look on smallapplianceparts.com for your part or search "small appliance parts" for a few other places that sell these parts.
Posted on May 20, 2010
  • Dave
    Dave Jun 08, 2010
    On an additional note, to get the side panel off so you can get to the controls you may need to remove a screw(s) that you cannot see is holding the panel on. Open the front (glass) door and see if there are any screws going in toward the panel that you're trying to get off. There may be a very long screw that is holding the panel on after you have removed all the obvious screws on the side panel. The screws will likely be right adjacent to where the door sits when it's closed. The screws are to the left of your oven controls just on the inside of the switch panel. You may need to remove one or more of these screws to get the side panel off. Once the screw(s) are removed, lift the side panel from the bottom. The side panel may have tab's on the top that are inserted into slots of the toaster body to keep it on tight. Lift the bottom of the panel up and pull it out of the slots to remove it from the body. You will now have access to all the electrical switches.
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
My TRO651 Toaster-R-Oven does not work on any function and the blue light does not come on. I removed the right side cover and checked all the connections, then I cleaned the two sets of contacts with fine...
May not be too hard to fix. On the thermostat, you will see 5 wires coming from it. black and white on top (leave those alone), and on the bottom of the switch, there are red white and blue wires.
The white wire with the burnt connector(from use) is the problem. I had that switch apart, seen how it works. The 3 wires at the bottom (red, white, blue) is like a spst center off switch with white being the common center wire. Red is for oven, and blue is for toaster. After I rebuilt the switch the first time, and it happened again, I just bypassed switch by connecting that burnt bottom white connector, to the red timer wire connector. Oven will work, toaster will not. The oven turns off when timer runs out. Can also unplug or turn down thermostat all the way so it does not use much power when done using till timer runs out. If you have a spst(center off) switch, you can mount that too to the side panel if you find one rated for it. Just make sure the bottom white wire is used as the common center wire.
B&D will not sell that switch that is broken. I tried that before I took that switch apart. Glad I did take it apart as I am sure their new switch would have failed quickly as well.
Aug 02, 2011 | Black & Decker TRO651 Toast-R-Oven Toaster...
Button to toast won't latch
THE BOARD IS BAD .the problem is b&d will not sell it to you . i had one that i DID FIX , there was a problem in the power supply on the board , i checked out the parts i needed there where 2 diodes , and an scr transistor i found bad . ordered them (with shipping 28.00 ) got them and installed . and the first power up POP the ic timer blew apart and damaged the two diodes . cost of the ic another 25.00 plus the other parts. so i now have around 60.00 in parts and 4 hours labor in to my great working 7 year old toaster oven ( that i only paid 25.00 for in the first place ) so unless your like me and never give up ,NO MATTER WHAT ! its time for a new toaster oven ......... if this answer helped please rate a 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Jun 19, 2009 | Black & Decker TRO360 Toast-R-Oven Toaster...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Toast button sticks and sometimes does not function. Sometimes it will work if it is jiggled.
I had the same problem which was getting worse. Eventually I took the oven apart by removing the feet, shell and front. Then I removed the circuit board on the front panel which has all the switches on it. We never use the "Defrost" function, so using a soldering iron, I swapped the "Toast" switch with the "Defrost" switch. The Toast function now works normally. I plan to get some spare switches for the next time one of these goes wrong. While I had one of them out I checked it out and a Panasonic P/N EVQ-PAE05R available from Digi-Key P/N P12192S-ND looks like it will do the trick.
Oct 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Black and Decker 0650
I have a Black & Decker CT0649 toaster oven. The timer switch on the toast control does not work and I took it out and took it apart. There is no way I can put is back together. Black and Decker will not sell me a new one!
If you have a broken Black & Decker CTO649 I would be interested in purchasing the two timer switches in it before you through it out, $5.00/each. (Negotiable).
I can be reached at alan.s.bitzer@power.alstom.com
Thanks
Al
Jul 14, 2008 | Black & Decker CTO649 Toaster Oven with...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
KitchenAid toaster oven Mod# KC010058
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Oct 21, 2007 | KitchenAid KCO1005OB 1400 Watts Toaster...
Oster 6295 Toaster Oven with Convection Cooking Logo
352 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
ray gallant
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
