Question about Bose 101BKB Speaker
HOW DO I TAKE APART BOSE OUTDOOR 101 SPEAKERS APART TO CLEAN
3 Suggested Answers
  • 4234 Answers
SOURCE: Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Posted on Oct 08, 2008
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
Can bose 901 VI beplayed at outdoor parties as suggested in mannual
Of course, however, since the speaker cones are paper, it would be wise to protect them from moisture (rain, pool splash, etc.) as the speaker cloth will not do this. Also, the wood used in the cabinetry is veneer and would de-laminate if exposed to moisture for extended periods.
Jul 31, 2014 | Bose 901 VI Main / Stereo Speaker
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
Bose Companion 2 speaker has crackly volume control - simple job to clean if I could get the unit apart!!! Any advice would be appreciated, thanks.
The problem with the crackly sound is caused by dust or dirt in the Reostat that controls the volume. it needs to be cleaned, there are a couple of different types of Cleaners that you can use. Just be sure its safe for the application. (of course the cleaner part is common sense)
Nov 16, 2009 | Bose Companion II Computer Speakers
How to connect my Bose Wave System to two outdoors Bose speakers?
It won't connect to externa l speakers directly but you could take the RCA output to an amplifier that drives them.
Aug 29, 2009 | Bose & Wave& Music System
Hook up brookstone wireless outdoor speaker
You cannot add other brand speakers to Bose systems. You must purchase the Bose second zone speaker amp and speakers.
Apr 26, 2009 | Bose (321GS) System
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Dan
Oct 08, 2008 | Bose 151 Main / Stereo Speaker
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
537 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
