Question about Silver King Refrigerators
Cools to 30 degrees no lower - Silver King Refrigerators
  • 10,515 Answers
Read the Below Guide :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 16, 2010
  • 4 more comments
  • miamidph May 16, 2010
    this is a freezer not a refrigerator. where would I find your answer?
  • taran_2005
    taran_2005 May 16, 2010
    Thanks for your response!!
    You selected Refrigerator. Not a Problem, Kindly Tell Few Questions :-
    1. Make and Model of the Machine?
    2. How long you have been facing this Problem?
    3. Any Other Symptom like Strange Noise, Non Working of any Component, Spark etc
    4. Do you have the Tools to Repair it?
    Let me know,so that we could Proceed.
    Hope i helped you.
    silver king freezer model SKF27 3 days replaced with new compressor and dryer
  • taran_2005
    As it does not Cools to 30 degrees or lower :-
    1. This seems to be a Fan Motor Problem. I have seen this many Times.
    2. It could be an Internal Leak which is not Repairable.If it's a leak but not foamed in, it can be repaired and the appliance regassed.
    Hope i helped you.
    Thanks
    is it possible that the thermostat control is not working, The comp does not turn off
  • taran_2005
    Yes, it could be a Possibility.
    Hope i helped you.
    Thanks
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How do i adjust AC temperature variance on a Honeywell TH5220D1003 thermostat
If you are talking about the difference between heating mode and cooling mode and the room setpoint, you can not change it. It comes from the factory with a 3 degree difference. In other words if you raise the heat setpoint until it is within 3 degrees of the cooling setpoint, for every degree you raise the heat setpoint the cooling will raise a degree.
About all you can do is increase the distance between the heat and cooling setpoint. To do this either lower the cooling setpoint to 3 degrees higher than the heat setpoint you want and then increase the cooling setpoint the desired setting. For example heat and cool setpoints are 67 and 70 respectively, and you want 65 and 73. Lower the cooling setpoint to 68 and then raise the cooling setpoint to 73. Now your heating will come on 3 degress lower than 68, the 65 you wanted and cooling will come on at 73. Remember, the thermostat new setpoints will turn on the cooling at 75 and turn back off at 73 and heat will turn on at 63 and turn off at 65.
You can perform the same using the heating setpoint, just have to look at it backwards. If you need to lower the difference I recommend a 8000 series thermostat. They are the most functional thermostat that Honeywell makes, be in mind they are about 3 times more expensive and many of the setting require a well trained tech to interpret and set properly.
Hope this helps.
Aug 24, 2014 | Honeywell Th5220d1003 Non-programmable...
Charging an air conditioning system
R22 systems should run a 68# to 70# suction pressue. If you look at the suction guage at 68# that is a 40 deg evaporator coil temp.
Nov 18, 2012 | Ruud Central System Air Conditioner
Just need to know if the temperature should be higher to keep the room cool or lower...mine is in F and goes from 68 to 86 degrees F...Please advise if it should be lower at 68 degrees to keep the room at...
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
Jul 21, 2011 | Sunbeam Heating & Cooling
The temp setting shows 78 degrees,lower to 72 degrees /it stays for 15 sec and returns to 78 degrees no codes
you may not be giving the a/c enough time to cool down to 72 the reason it goes back to 78 is that is the temp in the room at that moment put on 72 and give it about 20-30 min. to see if this helps
Jul 03, 2011 | Sharp AF-S120FX Air Conditioner
Wont allow me to set thermostat below 73 degrees?
You never said what type and model of thermostat you have....... If you have a digital stat You may have to lower the HEAT setting below 67 degrees if you want to set the AC to 70 degrees. If the thermostat has an Auto feature then it has to have a 3 degree differences between heating and cooling. On the newer models it does it automatically if you lower the Cooling setting it will lower the heating setting......It this doesn't help repost with more information so I can help you better....
Mar 28, 2011 | Heating & Cooling
The air conditioner is emitting cool air instead of cold air. I have the setting on cold and the temperature setting at 60 degrees. On these days that have been near and over 100 degrees, that cool air...
Typical temp split should be 15 to 20 degrees. A 75 degree return air temp should be in the 50s. Be sure coils are clean , if in that range the machine can do no more. If it is not, you likely have a refrigerant issue.
Aug 31, 2017 | LG LWHD1009R Air Conditioner
My roof air will only cool down about 10 degrees below outside temp. What should I ckeck first?
On a hot day (80+) check the temperature difference between the indoor coil's inlet and outlet, it should be 20 degrees lower under normal circumstances, if the air temperature is lower than that you may need to clean the indoor coil fins.
Next check the same thing at the outdoor coil; there should be about a 30 degree rise in temperature when the air exits the coil. If the temperature is higher you may need to clean the outdoor (condenser) coil.
Jun 14, 2010 | Dometic Rooftop RV Air Conditioner
Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Sep 10, 2008 | GE PTS25LHP Top Freezer Refrigerator
Refrigerators Logo
Top Silver King Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Silver King Refrigerator Expert? Answer questions, earn points and help others
