Question about Insignia IS-LCDTV32 32 in. Television
Easy Question It has been explained to me how to change out the cap or power supply for me set, however, for the life of me I cannot figure out how to remove the back panel. I have been told that I do not have to remove the entire back. Am I missing something?
  • 934 Answers
Well you are maybe and you'er not... Only the upper panel area needs to be removed. It may be a little stubborn after the screws are removed but that's all that needs to e removed...
Bill
Posted on Apr 08, 2008
My tv has no power, when plugged in the green light flashes constantly about once per second, pressing the power button has no effect. The only voltage coming from the power supply is 5v. Unplugging the...
It sounds like the standby 5vdc is working but the main board is not sending the PS_ON signal to turn on the 12vdc/24vdc power supply section and the BL_ON for the inverter board. I would look at the sch. to see if you have the PS_ON (3.3~5VDC) to turn on the power supply section first. I have a feeling you are having the main board problem.
All the LCD TV's operate just about the same as explain in my guide.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 12, 2011 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Power supply in my Sharp LC-37D43U quit in 1st qtr '09 and was replaced at a repair shop. Recently the TV won't turn on and there are no standby lights. I'm assuming the power supply is out...
The common failure in the power supply is due to cheap low quality capacitors, the replacement that was install probably has the same quality cap. I only use good cap from PANASONIC for my repair works.
The moudle is easy to replace, just remove the TV stand, all the back screws, and may be 4~6 screws for the power supply, it uses connectors so yoiu can easily remove them, just take good pictures before working on it so you will know how it goes back together.
You can try getting the module from www.shopjimmy.com, he is my main supplier for boards.
Just make sure to get the number as printed on the sticker of the power supply to get exact match, you can also contact him if you are not sure.
Here is the service manual: http://elektrotanya.com/sharp_lc-32_37d43u.pdf/download.html
Jun 14, 2011 | Sharp LC-37D43U Television
My tv wont turn on the red stanby lite is the only thing that is on nothing else works
The 5vdc standby power supply is working but the rest of the power supply may not be working, you need to openit up and inspect the capacitors int he power supply first.
Service manuals: http://www.polaroidsupport.com
Are you going to DIY repair?
Typical shop rate will be $150 and up plus parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Jun 08, 2011 | Polaroid FLM-2601 Television
No sound and no picture.Power comes on with red light changes to green. Replace caps (15) on power supply.
You need to check and see if all the control voltages (Power supply on) and DC output voltages are present. PS pin out: http://www.fspgroupusa.com/download/specs/FSP271-5F01_DIA.pdf
Please read my guide to see how LCD TV works.
Please post back what you find.
Mar 16, 2011 | ViewSonic N3752w 37 in. LCD TV
Q: Red standby light was flashing red for a few days. Now we can't get any power at all. lg model 32lc2du-u3 A: Power supply problem.... I can explain to you how to fix via email with detailed...
First: service manuals http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=32lc2du-u3%20&kategoria=tv&kat2=all
Second: most failure in power supply module is due to bad caps with domed top, you should inspect for that first, main AC fuse for main power.
Did you take out or look at the power supply yet?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Please leave rating if it helps.
Mar 05, 2011 | LG Televison & Video
I have a samsung ln40a550 LCD and had a problem with it , the TV wouldn't turn on. So i did some research and found out that samsung had some crappy capacitors, so i called them and they came and replaced...
I would think if SAMSUNG came out to replace the bad caps and the TV is still not working right, I would think they should fix it correctly, may be the person did not do the good quality jobs and left. What does SAMSUNG say about this? The bad power supply could have unstable DC and could have damaged the other boards inside the set. You will need to inspect the power supply yourself, look to see the soldering works are good and everythings are put back together correctly with correct polarity.
Then you need to verify all the DC output voltages before going any further, it will not be an easy job.
Learn more here;
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement boards:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Samsung+LN40A550&stock=all.
Dec 11, 2010 | Samsung LN40A550 LCD TV
TV will not turn on.It is plugged in .Is there an internal fuse . I had a power outage while the Tv was on.The power button directly on the TV will not work either.
Check the power source?Yes,near the edges the power supply board there is a fuse.That the board,where the power a/c cord plug into it.But new modern digital devices,never blown fuse as easy as analog devices though.Power supply board,have shorted parts in it some where and now the board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Sony KDF-E55A20 55 in. LCD Television
Clicking noise will not power on, changed 2 blown capacitors. May need eeprom re-set sounds complicated?. many thanks
IF THETWO BLOWN CAPS WERE IN YOUR POWER SUPPLY REPLSCE THE POWER SUPPLY SOMETIMES EVEN WHEN WE CHANGE THE CAP
THE POWER SUPPLY IS BAD
Jun 03, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Insignia NS-27lcd tv won't turn on
Well, take the plug that goes to the inverter board out which has the 12v on it. Check the 12v again at the power supply. If 12v is low you can possibly have 2 caps bad, the values should be about 1000uf/35v or there abouts. They set close to the plug. If that doesn't work then replace the Power Supply because there are no service manuals for lcd p/s. plus nearly impossible to locate individual ic's. Try Shop Jimmy.com for the P/S.
Apr 30, 2009 | Akai LCT3701AD 37 in. LCD Television
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
Insignia IS-LCDTV32 32 in. Television Logo
95 people viewed this question
Top Insignia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
