Question about Kenmore Elite 45986 Front Load Washer
The sensor for suds keeps coming on and stoping the machine
  • 37 Answers
The suds error is actually triggered by the machine not draining quickly enough. There are a few things that can cause this
  1. Trying to pump too high (usually from a basement)
  2. kinked or obstructed drain hose
  3. lint or other foreign matter in the trap/pump
  4. or actual oversudsing
If you have had this machine for a while and have had no problems and you have not changed additives or water hardness, then it is probably not oversudsing.
Hmmmm, sorry about the run on sentence.
If you have any more questions after checking these possibilities, post them and I'll be more than happy to help.
Good Luck
Posted on May 16, 2010
My Beko WMP601W wont drain, clothes come out soaking wet, also the draw keeps oozing with suds, all over the floor???
You need to check the drain pump is free of any obstructions, can you hear the drain pump operating?
The machine will need several short wash cycles to flush out the excess soap which is causing the suds.
Mar 26, 2017 | Beko Washing Machines
What does Error sud mean in washing machine diamond 7k wf8692nfv?
USUALLY A RESULT OF USING TO MUCH DETERGENT PER LOAD AND THE SUDS SENSOR COMES ON LIMIT UR SOAP USE AND TRY RUNNIING A FEW WASH LOADS WITH JUST HOT WATER
Jan 28, 2016 | Washing Machines
Dirty whites
probably your soap, or there is a soap contamination issue......run the machine without adding any clothing to it and see if it suds up or not....I'm suspecting you'll get suds...a little to a lot......if I'm right, then turn it to hot, and add a half gallon of white vinegar to it and let it cycle thru....repeat that for one more cycle...then test the machine one more time for suds without adding any cloths or products to the wash......if the suds are gone or just reduced, then keep repeating til the water runs clear
and to clean the dirty whites, try washing in cold water first, then hot..and obviously the whites with just whites, no colors allowed.
once you clear up the extra suds, try CHARLIES SOAP....it workd great and helps keep the machine clean
Apr 22, 2012 | Zanussi F1245W Front Load Washer
An error code keep coming up. sud reads on the display instead of time, and clothes are not done still wet
The part is call analog pressure sensor switch . And you are using the wrong soap for the machine
Oct 18, 2010 | Kenmore Elite 45986 Front Load Washer
First washer stoped and SUD was on the ( readout - Where the Timer is ) then now it has a code F35. What can I do ?
Hello there:
"Sud" SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Oct 03, 2010 | Kenmore Elite 45986 Front Load Washer
Why does my washing machine say f35 and sud
The F35 indicates a water level pressure sensor failure. The SUD is normally displayed when there is excessive detergent suds in the tub. A loose wire harness connection could be causing this problem is there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then this component will need to be replaced.You can order a new analog water level pressure sensor from the Sears PartsDirect website.
For knowing where the analog pressure sensor is located in your machine.Please click on the link below:---
http://media.fotki.com/1_p,wbwffdgkwtfwqstxgtqsskgwtqkq,vi/kdfbtfqwfxkddstsrtqxkdwsfgwwk/1/1303472/5961857/image46273img-or.jpg
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Kenmore Elite 45986 Front Load Washer
Suds, and F35 keeps coming up when trying to wash!
I would put bleach in the detergent slot, run through each cycle. Then run the cycle again with just water. These are really touch when using detergent. Just a little bid of suds sets these things off.
Jul 26, 2010 | Kenmore 44102 Front Load Washer
My washer won't drain.. it seems like it isn't spinning...
Are your useing HE detergent. With these washers you need to use the detergent that has an "he" on the bottle. SOunds like the washer stopped on suds. I believe these washers have a sud sensor in the pressure switch. either that or there maybe something in the pump. The metal sound would be the tub bearing going bad. Like i said, if you dont use HE detergent, too many suds buld up and it get to the tub bearing and it corrodes it. But i would check your pump out for any obsttruction and if clear then i would think its stoped on suds. try putting it thru couple washes without detergent to clear out any suds it may still sense.
Aug 03, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer flashing F then went to SUD
Drop the drain hose so that it is lower than the drain and let all the water run out of the machine. Open the door and remove all washing. Let machine go through rinse cycle with some milk mixed in with the water, (pour the milk into the soap container, about one cup) and make sure there are no soap suds left in the machine. Check that you are using washing powder which is recommended for front loaders.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
117 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
