Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher is not cleaning well and dishes remain damp and wet
I have had bosch dishwasher for the past 4 yrs, it was working well but for sometime now I have noticed that the dishes are not cleaning well, there is residue left behind which I have to clean up every day and also the dishes remain moist and wet which then I end up drying with a towel. Any suggestions. Also how and what should be done for dishwasher maintenence?
  • Bosch Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
53hg
Posted on Sep 29, 2010
Our dishwasher takes about 3-4 hours to run a cycle. My brother has the same model and it takes about an hour. Is there an adjustment that we can make to correct this? Thanks, Karla
make sure that your filter in the bottom is clean and if you are using the automatic wash cycle, it will wash until the water is clean. Sometimes it will take an hour, sometimes it will take close to 2 depending upon the level of dirty dishes in the dishwasher. And don't rinse! They work better on dirty dishes.
Jan 05, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My Bosch dishwasher is only 2 yrs old and for the following two nights does not want to pump out the water. If I drain it, it sometimes starts the cycle and sometimes not?
If no warning lights show up, then it is a matter of finding if the outlet is blocked somewhere. I am assuming the fact you can drain it manually means the pump is ok. Perhaps some sensor which is covered in muck.
I would start by cleaning the filters at the base and then running the unit with a dishwasher cleaning kit (without dishes in it). Finish cleaning kit is quite good and the instructions are on the pack.
By the way these units normally have a 2 to 3 year warranty on some parts. I am assuming you have the proof of purchase so that you can call the Bosch support guys.
May 07, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Clean dishes are wet
1)please check the rinse chemical passing correctly.
2)check the boiler heater working.
Jan 08, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
The rinse agent light is on and the water will not spray out
NO WILL STILL WORK IS ONLY A FLOAT SWITCH TO WARN YOU,HOWEVER RINSE AGENT DOES AID THE DRYING PROCESS SO WITHOUT YOURE DISHES WILL BE WET AND SMEARY
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Have bosch she45 that stays wet inside after cycle completes. some of the dishes are wet also, how do I stop this
First of all, Bosch is my Favorite! Secondly, maybe your heated dry button is not on. Are you keeping the door closed until the dishes have had a chance to completely dry? This unit has a system that drys with the walls of the d/w as long as the door remains closed. I hope this helps you. :>)!
Aug 14, 2009 | Dishwashers
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
209 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
