Question about Intertherm P3RA-048K Air Conditioner
Why is the highside 150psi and the lowsidee is 70psi and the compressure is very hot
  • 2 more comments
  • laura Newman May 16, 2010
    What are the indoor and outdoor temperatures? What is the temperature of the suction and liquid lines?
  • gingerbr1 May 16, 2010
    suction 40
    liquid 85
    indoor 90
    outdoor 80
    r22 unit
    suction 40
    liquid 85
    indoor 90
    outdoor 80
    r22 unit
    suction 40
    liquid 85
    indoor 90
    outdoor 80
    r22 unit
  • 53 Answers
The unit seems to be at normal pressure but could use a cleaning on the coils of the condensor..but remember after cleaning do another freon check it could show thats it is low that is what usually happens after u clean hope that woked for you
Posted on May 17, 2010
    Guru:
  • 415 Answers
Hi Ginger.............
Based on the information you shared, I would first start with the metering device.......It doesn't sound like it is metering the refrigerant properly. If your system is using a TXV indoors, check the sensing bulb....make sure the contact between the bulb and the suction line are clean and tight. Make sure the suction line and bulb are well insulated.
Posted on May 18, 2010
Can I replace the tank drain on my Porter Cable 150PSI 6Gal pancake compressor with a ball valve?
As long as it will physically fit and the rating is above 150psi -Yes.
I say above 150psi because if the compressor pumps to 150psi, a 150psi valve is on the hairy edge of it's max limit.
Oct 13, 2017 | Porter Cable Air Tools & Compressors
2006 Ford Fusion Air Conditioning compressure not turning on.
Thats pretty high if the system is not running. Average pressure on the low and high side should be near outside air temp.
Normal low side is 30-40 psi and high side is 200-250 psi when the system is running and the freon charge is full.
Aug 28, 2012 | 2006 Ford Fusion
Can the a/c on 2002 Ford Explorer be re-charged with Freon or is it actually a sealed system?
All systems can be charged, there are valves to charge the system up, theres a highside and a lowside valve, the highside is the larger valve and the lowside is the small valve. the system is charged through the low side valve. good day.
May 15, 2011 | 2002 Ford Explorer Sport Trac
2008 honda pilot a/c is not blowing cold air, blows hot air. bought truck in 2007.
the most common problem with honda and acura is the magnetic clutch failure on the compressor , test to see if you are getting power to the clutch assembly with the car runningand the A/C on max if you have power the compressure clutch is bad if you don't ck the compressure fuse and or the clutch relay.
May 05, 2011 | 2008 Honda Pilot
Too hot little cold
Very possible your condenser is extreemly dirty and is turning off on a high pressure cutout. suggest you clean out condenser with compressed air. Brushing is not enough. also, check if condenser fan(at the compressor) is working.
May 21, 2010 | LG Heat cool Window Air Conditioner
Works but won't get hot
check or change the highside limit switch located on the back of the machine once the rear panel is removed and on the heating element housing it is oval shaped and has 1 wire on each end of it
Jan 20, 2010 | Dryers
My 02 sonata a/c system doesnt blow cold?
Ok... you wrote "lock was all dry but after i charge the system it start leaking from the same place that the original was leaking,(center of ac compressure.)" Sounds like you should have 'OVER HAULED' the existing/used compressor before installing it... OR bought a recondition/new compressor (ya think?). It appears both the original and used compressors have the same defect.
Jun 24, 2009 | 2000 Hyundai Sonata
Ac highside charge line location
the high side should have a black cap with a letter H on it.... if you dont see it then look for 2 valves that have caps on them, the larger of the valve is the high side, the smaller is the low side, the low side is the only one you want to use if you are refilling the system you do not want to mess with the highside... the low side pressure makes it so you can recharge the system, the highside will not work to refill a system if you are using the store bought recharging systems... and the valve on the recharger will only fit low side... hope this helps you... the highside should be on the pass. side towards the rear o the engine...
Jun 23, 2009 | 1997 Volvo V90
Rooftop unit economizer not responding. I tried to simulate hot ambient temperature, but compressor did not kick in, check the resistance of OAT sensor and it's good.
1.check spare parts of compressure.
2 check wireing of compressure.
3. check voltage.
4.check continuti of compressure.
5. check discharge pressure.
Apr 04, 2008 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
133 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
