Question about Sony Cyber-shot DSC-T20 Digital Camera
Cyber-shot dsc-t20 error c:13:01 RE-INSERT THE MEMORY STICK MESSAGE
I was using my camera as normal today. have some special childs bday pics on there, then all of a sudden it swtched off. when i turned it on again it keeps coming up with the message Reinsert the memory stick, which i keep doing. nothing happens. ive taken battery out etc. still can retrieve the pics. error code c:13:01 flashes in the background.
I tried one of my other memory sticks and it is fine. so theres obviously a prob with this stick. is there any way i can get the pics downloaded. tried putting it in an addapter which i can link and downloadfrom my printer but it thinks nothings on there.
Please someone tell me i an take it somewhere and get the pics bac????!!!!
  • 1 more comment
  • rassel Apr 14, 2008
    im having the same exact problem. i really want this memory card to work in the camera because it is a 1 GB and can hold a lot of pictures
  • Anonymous Jun 24, 2008
    hi i have the same problem
  • ajay_nv Aug 20, 2008
    I seem to have the same problem, but for me the data is very important and would like to retrieve the pics.
Posted on Mar 31, 2008
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Memory Stick File Error
Could be that the camera does not support a 2G stick. Check the operators manual.
Aug 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
"re-insert the memory stick" error
Try cleaning the contacts on the memory stick. I've read that a pencil eraser should be used; I used a soft cloth (T shirt) & then I blew into the slot in the camera that holds the memory stick to clean anything that may be interfering with making a good contact. First try: success!
Aug 04, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Cyber-shot DSC-W35 format error c:13:01
Software for Memory error correction is available on charge basis to get data/ pictures.
Jul 29, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Memory stick error
Hello, there is a contact error. In most cases it can be the connector itself. Please try to clean it with non greasy contact spray. Best regards, Arpi PS: if you need more info please advice.
Jul 22, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
245 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
