Question about Exercise & Fitness
I have an Action Sports T16 treadmill and we have just relocated home. When I plugged it it, the red light comes on to indicate it has power but I hear a ''click'' and the dashboard doesn't light up or operate. The incline/decline still works but the treadmill wont run or turn on ?
    President:
  • 832 Answers
The vibration of the move may have loosen the connectors. Unplug unit remove motor shroud you will see the motor control board pull and reconnect all connections also check the connector in upper electronics then on unit see your display works and see if you have motor and belt movement.
Posted on May 16, 2010
The console does not power up...I reset the reed sensor to go closer to the magnet, still does not get power. Is there something else I can try
Trouble Shooting Treadmill with No Power - YouTube
? 1:23
https://www.youtube.com/watch?v=N6Yg5S0WML8
Jan 20, 2011 - Uploaded by WilkinsFitness
Trouble Shooting Treadmill with No Power ... Disconnected wiring harness at console can also cause no power as well as faulty harness.
Troubleshooting a Treadmill That Won't Start - Livestrong.com
www.livestrong.com > Sports and Fitness
Jun 6, 2015 - If your treadmill doesn't start, you will need to troubleshoot the possible cause. ... If your treadmill is not properly plugged in, power surges and fluctuations in your ... If the console lights up, but the treadmill won't start, the motor ...
How to Determine If a Treadmill Console Is Broken ...
Dec 29, 2015 | Exercise & Fitness
Will not come on. Has power to it. Is there a restart button? a fuse? What?
Hi Hannah.
The manual for this treadmill can be found here:
http://www.landice.com/sites/default/files/Landice_PST5_Manual%2372116_PDF%203-1-15.pdf
What stands out in these instructions is that there is a red, magnetic safety key that must be connected to the panel to run the treadmill (PDF page 4). Also there is a diagnostic mode covered on PDF page 19 that should let you find out if the treadmill thinks it has some other problem.
Hoping this helps
Good Luck
D
Nov 19, 2015 | Landice L7 LTd Pro Sports Trainer...
ASI Image Pro 2 Treadmill will not start
PLEASE see the video and proceed according. God bless you
Dec 10, 2013 | Exercise & Fitness
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
I need the code for sharp tv please
Configuring codes:
  1. Turn on the component that you want to set up. In the code listing find the 4-digit code numbers for your component brand.
  2. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  3. Release the component key.
  4. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  5. Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
  6. Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed. Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
    The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
  2. Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
  5. Press "0" - "9" The green light will blink as codes are sent.
  6. As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
  7. If none of the codes turn your component off, return to step 2 and start over.
Code Readback:
  1. Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
  2. Release the component key.
  3. If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
  4. Press the "enter" key.
  5. Count the number of times the green light blinks. There will be four numbers, separated by a two second pause. The red light will tum off after the remote is finished reading numbers back. Make sure you write the code number below for future use!
Multi-Component Power On/Off:
    The Jensen remote has the ability to turn On/Off multiple components at once. When you perform the following steps, you can turn On/Off the TV, VCR, Satellite, Cable Box and Audio Receiver.
  1. Press the "action" key.
  2. Press the "power" key. Note: This feature does not work for DVD and CD.
Volume Priority Punch-Through:
    When you press the volume keys on the remote they will control the volume on your TV. If you have a home theater system and want the volume keys to control your receiver only, you may set your volume priority to the receiver.
  1. Hold the "RCVR" key down until the green indicator light comes on. The green light should come on after about 3 seconds.
  2. Press "RCVR" key.
  3. Press "Vol+" key. To disable the volume priority you have to set and return to the default.
    To change back to TV priority:
  3. Press "Vol-" key. The volume priority will now default to the TV volume.
hope this helps
Robb
Apr 22, 2010 | Jensen SC-570 Remote Control
The monitor will not come on. The indicator light just stays on red. We will unplug it and plug it back in, the power indicator light will flash to green then return to red.
You will more likely to have bad caps in the power supply which when they failed, will take out the fuse and MOSFET in the backlight inverter curcuits also. See example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Exercise & Fitness Logo
162 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
