Question about Homelite Garden
Saw will start and idle but when you give it gas it dies
    Brigadier General:
  • 4,088 Answers
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Pay particular attention to the placement of the gasket/diaphragm in the lower section of the carburetor. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Hope some of this helps!
Posted on Jul 19, 2010
My Durango starts if I give it gas and stalls when I let off the gas won't idle, help what to look for?
My car dies when I let off the gas - CarGurus
www.cargurus.com > Questions > Dodge > Durango
CarGurusDec 5, 2012 - My car dies when I let off the gas - I have a 2000 Dodge Durango SLT, I bought a month ago. I noticed it had a slow start but it still started and ran fin... ... Also, the oil pressure was high until it could idle by itself then it was back to normal. ... sometimes if you give it more gas it stays running but now it won't ...
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. I can pump the gas and it will stay running but if i hold the peddle down or . ... thatdies on me at stop signs and when I take my foot off the gas pedal. .... and truck pops..misses and runs like crap and wont stay on unless i give it gas, ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
www.dodgedakota.net/boards/v8/4240.html
Aug 9, 2003 - 21 posts - ‎20 authors
Dec 21, 2015 | 1999 Dodge Durango
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
2000 chevy tahoe starts but dies when you give it gas
th sorry th
at answe dont make any sence considering he said it wont run when he touches gas.. how is he going to keep it reving if it stalla as soon as he touches the gas?????
Nov 07, 2011 | Cars & Trucks
After starting and letting it idle for 30 seconds I start to cut but it starts to die when I give it gas it goes for a while then dies
What I do with my stihl saws is after starting I let it warm up for a few seconds and then run it at full throttle for about thirty seconds. If your saw does not want to keep running I would check to make sure air filter is clean. Next you can adjust carb.setting for idle and hi speed,check your manual for instructions. Also I would remove and clean spark plug,check gap and reset or replace as needed. Make sure your gas oil mix is proper and gas has not been setting for a long time,no more than a couple of months without some type of fuel stabilizer. I use either STA-BIL or sea foam at a rate of 2 to4 ounces per gallon of gas. About the only other thing I might suggest is to check the feul filter. They usually are located on fuel pick up line inside gas tank and can be a pain to get to. Good luck and I hope this helps Thanks
Nov 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan chain saw mod. SM4018 Hard to start & won't accelerate
Your carburetor needs cleaned. It may also need a carburetor kit, depending on how old or how long it has been since service. While you have it apart, you may as well clean or replace the air filter and check fuel lines for cracks or brittleness. If you need tips on how to clean carb. or changing fuel lines, just let me know.
Jim
May 30, 2009 | Poulan Garden
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
106 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
