Question about Roper REX4634KQ Electric Dryer
Broken dryer belt . need replacement belt . - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Posted on May 16, 2010
Magtag dryer drum will not turn is there a belt that needs to be replaced
If you hear the motor run, but the drum doesn't turn, it's most likely a broken belt.
Mar 11, 2014 | Maytag Neptune MDE7500AY Electric Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
The dryer is plugged in and blows really hot but the drum does not turn- any idea where to start
The dryer has a belt that goes around the drum and is driven by a motor in the bottom of the mach. Open the back or lay it down on a bucket on the front and look for the belt to be off or broken.
Feb 04, 2010 | Dryers
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
Roper REX4634KQ Electric Dryer Logo
67 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
