Question about Sony ECM-44B Lavaliere Microphone Microphone
Humming sound when plugged into a cannon video
I'm doing interviews with a cannon HD camcorder and am using a Sony lavalier mic model ECM-44B plugged directly into the camera with a good monster cable. There's a humming noise I can't get rid of. How do I eliminate this problem?
3 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: new noise
sounds like a ground issue to me. that sounds like either 60 cycle hum, or a loose or broken ground. You can probably do an ohmmeter check, first, with no power, and see if you have continuity. That's not unusual for mikes of the seniority of your equipment.
Posted on Feb 16, 2008
  • 1138 Answers
SOURCE: how to use Sony Electret Condenser Mic ECM-102
The closest manual I find is at http:// www.mutinymedia.co.uk/tie_clip_mic_files/ecm44b.pdf. Shows where the battery compartment is and gives specs and usage tips.
Posted on May 19, 2009
WIRE A SONY ECM 77 TO AN XLR FOR EXTERNAL PHANTOM POWERING.
wire it to a audio mixer on the mic input
these devices have phantom powered input.
Nov 11, 2014 | Sony ECM77B Mini omni lavalier mic -
Hi i have a Sony hdr CX550 handycam camcorder
Most mics will work if the plug fits the socket on camera and it fits on the hot shoe okay, I never use Sony mics on my Sony camera, you end up paying for the name, not the item.
Jun 19, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
How to connect lavalier mic to panasonic dvx100b
Pretty easy, connect it to the xlr connector (hope your lav do have xlr connector) then swith the external mic switch on, phantom power switch to on, and front switch to mic (not line) and ajust the level.
Sep 14, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
I have a bunch of ECM 44b microphones, I'd like to repair them.
It has been my experience that the wires going into the amplifier assembly is broken. What I do is cut the wire about 2 inched from the strain relief, remove the old wires from the amplifier and reterminate the amplifier. This fixes 90% of my problems. The other 10% is a broken wire at the microphone end of the cable. This cannot be fixed as the cabling has been injection molded.
May 31, 2009 | Sony ECM-44B Lavaliere Microphone...
External mic for Panasonic DVC80p
on page 49 of your owner's manual, the operation of the mic input switches is described.
Mar 04, 2009 | Panasonic AG-DVC80 Mini DV Digital...
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
MY JOB DEPENDS ON THIS!!! SONY DSR PD 170 AUDIO PROBLEMS!
if you use original mic(boom mic), rec ch select (ch1.ch2 and ch1) if you choose ch1 it means only 1 channel you want to rec, ch1.ch2 means you select 1 in for ch1 and ch2.input level depend the volume of your input for original mic use mic if the sound around not loud, use mic att if the sound around to loud. +48v for mic original use on, if you use off mic don't work,for input 2 same with input 1.if the original mic don't work try to push the reset button. if don't work, i found that some cam, have bad contac inside the switches
MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
MV630I
the best is to have a mic plug in on a camcorder its more advantage than using a mic built in. hope that helps you
CHARCOIS
Jul 23, 2008 | Canon MV630i Mini DV Digital Camcorder
New noise
Feb 16, 2008 | Sony ECM-HS1 Gun Zoom Microphone
Sony ECM-44B Lavaliere Microphone Microphone Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
