Question about Sony KDF-42WE655 Television
Sony 62" Grand Vega HD TV
1. Red LED flashing on TV, book says needs servicing.
2. Try turn tv on switches over to green LED 5, or 6 times, then goes right back to red flashing LED.
3. I pulled the bulb, and checked to see if it was blown. It looks good, it is not burnt, the filament wire is still connected.
4. Re-installed bulb. With the cover remaining off I can see the cooling fan through the hole where the bulb is. At this point I tried to turn the tv back on, to see if the cooling fan was even trying to start, and it did not.
5. Any advice on what to do next, is my cooloin fan bad? If so some install instructions would be great. Or any other advice I should try next?
  • RGIBSON3 Oct 22, 2008
    I have same problem
    I am told my power supply is bad
  • Any Guy
    Any Guy May 11, 2010
    How many times is the red light flashing when it shuts off?
I replace the lamp and turn tv back and have lines in picture
Posted on Jan 24, 2010
I do not know what model you have but I had the same issue happening pixel by pixel. It was the optical block that Sony fixed on an extended warrant as they had a problem. If that is the problem go to the Sony sight and they have instructions
Posted on Nov 04, 2008
HELP, my 5 yr old grand vega is turning blue all over, getting worse. neila
    Problem Solver:
  • 14 Answers
JUST BECAUSE THE BULD NOT BLOWN DOSENT MEAN THAT IS GOOD I HAVE 40 OR SO BAD BULBS AN HALF THEM ARE BOT BLOWN HAVE A SERVICER TEST IT AN THEIR IS A TRIP SWITCH ON THE OUTER COVER THAT TELLS THE TV IF THAT COVER IS OFF OR ON WILL NOT START IT THINKS IT IS OFF
Posted on Oct 24, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Dec 21, 2008 | Sony KDF-42WE655 Television
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Apr 24, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KDF-42WE655 Television Logo
839 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
