Question about ASUS P5RD1-VM Motherboard
How to install window XP without floppy disk on asus P5RD1-VM
Hello!
sir please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find .please solve this problem i am in big trouble.
thanks
hamid sheikh
[email protected]
  • 1 more comment
  • meetakshay Jan 30, 2009
    how to install xp without floppy disk
  • Anonymous Apr 03, 2009
    when i was trying to open asus motherboard cd that time it shows the massege box its name"ausuhwio" &
    the message are"can't Create kernel Mode Driver services" when i clik ok then it shows "can't load ASCDDMI.DLL"
  • nup_pan Apr 12, 2009
    mr map9966 i dont know how u install and where u install win xp when it unable to detect any sata harddisk
Dear mike,
I too face the same problem, here the window xp cdrom did not detect sata drive. but the bios detect sata and list the drive during bootup. since P5RD1 uses ali-chip set, I think only option is through floppy. we will not be able load the driver and update the system later because no drive exist if only sata drive is present. I do not know whether to say Asus motherboard is faulty. I have seen similar procedure for Ndiva boards also.
bye
Hemachandran.
[email protected]
Posted on Apr 02, 2008
@font-face { font-family: Cambria Math; } @font-face { font-family: Calibri; } @font-face { font-family: Tahoma; } @font-face { font-family: Segoe UI; } @page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif" } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } P { FONT-SIZE: 12pt; MARGIN: 0in 0in 16.2pt; FONT-FAMILY: "Times New Roman","serif"; mso-style-priority: 99 } SPAN.EmailStyle18 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle19 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle20 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal } SPAN.EmailStyle22 { COLOR: #1f497d; FONT-FAMILY: "Calibri","sans-serif"; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } You need files in setup. Extract to floppy (all of them) F6 at setup. add a floppy drive.. or create another XP setup disk and place SCSI driver accordinly. You may have to take out the HDD - find the drivers for that HDD at western digical - m5287.sys
ULISATA.INF
ULISATA.CAT(optional)
http://www.techpowerup.com/downloads/408/ULI_SATA_RAID_Floppy_Driver_v6.2.2.1_Beta.html
copied those files in a floppy inside a folder "WIN_XP".. then during setup f6 for driver selection.. then i just located tat floppy for drivers and my drive thus got recognised
Posted on Jan 26, 2009
  • Anonymous Jan 26, 2009
    You may have to take out the HDD - find the drivers for that HDD.
    m5287.sys
    ULISATA.INF
    http://www.techpowerup.com/downloads/408...
    located floppy for drivers and my drive thus got recognised
Plz solution this problem
Posted on Nov 19, 2008
    President:
  • 2,351 Answers
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Posted on Mar 31, 2008
  • Mike Peluso
    Mike Peluso Mar 31, 2008
    To get into your bios press the Delete key every 2 seconds just as you start the PC. Your SATA drive should be shown in the bios main window. Go to Advanced section in bios Pg. 2-24 to
    SATA should be enabled.
    Go to Boot device priority. Pg. 2-31.
    1st Boot Device = CDROM
    2nd Boot Device = SATA
    3rd Boot Device = You choose or Disable.
SOURCE:
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
How to install windows xp in p5rd1-vm? when installing windows xp it goes no hard disk found. cant find sata hard disk. please help me about this problem.... thanks!
Make sure all the connectors are plugged in and in the correct spots. Then go to the bios and enable the SATA drives to be read. After that you should be able to boot from CD and install XP.
Jun 16, 2010 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Hard disk is not detecting when I try to install windows 7
Hi
You should find the drivers you are looking for on the Asus website.
Here's the link to their download page,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that help,
MK Support
Mar 15, 2009 | ASUS P5RD1-VM Motherboard
Please help urgent
hi.......
u can download them from http://driverscollection.com/?C=71 and u can find ways to install the sata drivers without a floppy at http://www.tacktech.com/display.cfm?ttid=414
Nov 21, 2008 | ASUS P5RD1-VM Motherboard
Please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find, or where from i get the floppy in...
use Nlight research this software in the net and you will find the answer works on laptops too the process is called slipstreaming. the process of witch you integrate the sata driver to the xp intallation disk to provide the necessary driver you required first download the driver you need then use Nlight to integrate the driver to the xp installation disk of course you will need another writable disk to accomplish this. thank you
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
5,530 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
