Question about Yamaha RX-V663 Receiver
Subwoofer I'm wondering if anyone can help me to find out why my sub-woofer doesn't work when connected to my Yamaha RX-V663 receiver. I know it isn't blown and it still works but when i listen to music or watch movies no signal is sent to it. i have it connected to the line level input and Ive also tried switching cords. any suggestions?
  • 46 Answers
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Posted on May 16, 2010
No sub woofer volume
Make sure Subwoofer power is on and connected with RCA cable in correct place.
Go into setup of "Speaker setup" and select 5.1 setup. Activate subwoofer to YES if setting is No.
On some Amps you need to select front speakers to SMALL even if you have large speakers to enabled subwoofer.
Sep 08, 2014 | Yamaha RX-V375 5.1 Channel Home Theater...
I have already purchased a yamaha receiver rx-v667 7.2 channels and I am looking for a subwoofer. Before purchasing the subwoofer I would like to understand how many connection options I already have: LFE?...
The 667 has two line level outputs to feed a subwoofer. They are identical. You only need one for most sub woofers. You need a suitable length pin audio (RCA) audio cable to connect.
Feb 17, 2011 | Yamaha RXV667 Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Feb 11, 2009 | Polk Audio PSW10 Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
Yamaha RX-V663 Receiver Logo
284 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
