I have got bush lcd27tv006hd tv. When it is switched on the light on the bottom right just flashes and nothing happens no picture no sound.
  • 6 more comments
  • Anonymous Jun 29, 2008
    I have the same problem. I have checked the fuses but they are ok. the red light just flashes on and off
  • benholloway Jul 17, 2008
    exacly the same problem here.
  • mandyclarke2 Jul 27, 2008
    Hi I have the same problem. I bought the TV just over a year ago so out of warranty! I have tried everything so please let me know if you find a solution.
  • Anonymous Jul 29, 2008
    We purchased the same tv and after only 2 years the tv gave a large flash and bank and then went blank I would take this tv back and get your money refunded as some time down the line yours will pack in too.When the bottom button flashes just push on of the buttons on the remote ie; the 0 button in my case and the tv should come on hope this helps.
  • marierogers Nov 11, 2008
    I have the same problem with my TV standby, light just flashes but nothing else happens tried everythin ie pressing all the buttons anything else I can try.
  • Anonymous Nov 25, 2008
    whilst watching the tv the picture started flickering and after a min or so it turned off, now the standby button just flashes but we have no sound or picture,
    the tv is 18 months old
  • rygza Jan 18, 2009
    if anyone knows how to fix this, mail me [email protected]
  • silver43 Mar 12, 2009
    Had same problem twice Bush fixed it once but i had to get it fixed by a repairman cost me 90 quid in my own home good value by Airwaves TV google them one guy who is mobile very good service !
    New Friend:
I know this problem was a couple of years ago . . however, I bought a BUSH 27" 'factory refurbished' for my son and it lasted a couple of years and then this problem with the standby lamp,etc occured. I followed a couple of threads regarding 1000uF capacitors on the power supply board relating to the 6volt output side and now all is well. TV now working :-)
(Did change for higher voltage spec. as recommended!)
Many thanks to all who supply info on websites like this one.
Posted on Aug 28, 2010
Took Mine 2 A Television Repair . . . Something Wrong With The Power :S Burning Out Or Something. Cost £110 To Fix . . . And Recomend Turning It Off Every few Hours As It Gets Hot
Posted on Sep 02, 2008
SOURCE:
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
Power light inside ?sound screen comes on but nothing happens when standby/power switch is punched light begins to flash on and off but still nothing happens--no sound, no picture, no static, nothing. Is...
Yes,the tv power supply board probably have dead components,likely a couples of capacitors on the power supply board have gases leakages,it dead,not funsctions any more.Take it to the tv shop pay for trouble & repair for you,this tv name are spacially made for and sell by the Target stores only.Very limited whole board parts,available on the net to buy.
Jun 24, 2010 | TruTech PLV1615T 15 in. LCD Television
Bush lcd27tv006hd no power ,no stndby lights
Open the back cover of the monitor.. check the fuse at the power supply board... If the fuse is open, replace with same value.. at the power supply board check for any blown capacitor and replace it with same value. Check also the power cord for open connection.
Feb 04, 2010 | Bush 5693D 24" TV
No power
Check the power cable and test a different power outlet.
If you are in UK also check the fuse inside the TV power plug.
If you do not find anything wrong , then either the fuse on power board, or one of the power board capacitors had blown, and the TV must be disassembled and tested to fix the problem.
Feb 18, 2009 | Televison & Video
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
No picture No sound
Hiii..
What number of the chassis of your tv set ?
Thank's
[vrya]
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Televison & Video Logo
804 people viewed this question
Top Televison & Video Experts
Ekse
