Question about Quorum Ceiling Fan - 138880
Quorum ceiling fan remote not working with fan
  • 103 Answers
SOURCE: Quorum ceiling fan
Try this site:
http://lightingbygregory.com/lighting/product/qr-7-1100-04.html?lbgc=biz_184052
Hope this helps, and please rate my answer, good or bad.
Posted on Feb 04, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
  • 45 Answers
SOURCE: Power went out and now ceiling fan won't work
It is quite likely that the unit has an internal surge supressor/fuse that blew when the power went out. Tou will need to open the housing to the fan motor and inspect the fuse. Once you get the fan working, the remote will work just fine.
If the problem is the remote itself, then it is possible, though highly unlikely that the remote code has been wiped out that connects the remote with the receiver on the main unit. If so, hopefully there are reset/reprogramming instructions in the manual.
Posted on Sep 07, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Manual for quorum 135525-44 ceiling fan
What's the problem? If you need a manual call Quorum @1-800-443-4626
May 23, 2016 | Quorum Dryers
How do I change the halogen bulb. I have the right size but it fits too loosely. My first bulb blew up. This is for the quorum Astra ceiling fan.
With the power off, inspect the socket and see if the contacts have been pressed down. You can bend them back up slightly using a small tool.
Make sure you do not handle the halogen bulb with bare hands/fingers. The oils in your hands will case the bulbs to fail. Use a cloth when installing a bulb.
Mar 17, 2015 | Quorum Dryers
How to reprogram remote for liberty fan
It was an add-on remote so it really depends on the receiver. Locate the receiver, probably in the canopy cover at the ceiling, and see if it has 4-5 dip switches. If so, just change the settings by changing one of them, by pushing it up or down. Now, open the battery compartment of your transmitter and match the setting you just did to the receiver. BOTH have to be set on the same frequency.
Aug 16, 2014 | Quorum Liberty 4952544 Ceiling Fan
Is there a Guide for Quorum Ceiling Fan?
Your best option maybe to contact Quorum International directly and provide the details of the problem including model number of your fans.
Quorum International manufacturer of designer coordinated lighting...
Aug 01, 2014 | Quorum Dryers
Where can i find parts for Quorum ceiling fans online?
u can type the fan make and model in your computer and get them just about any where.
Oct 03, 2010 | Quorum Ceiling Fan - 138880
On all three settings the fan runs very fast, no slow speed.
If it's a remote fan try completely cutting off the power at the breaker box for a minute or 2 and turn it back on. Mine does that occasionally and that seems to re-set whatever it is in the fan that causes it. Hope it helps.
Oct 01, 2010 | Quorum Ceiling Fan - 138880
I have a quoram 73000 remote that the previous owner of this home uses to control a ceiling fan as well as the canned dimmer lights above the fan.I hink I just need to reprogram the remote because it...
I will assume you checked the batteries? These units have sequence matched signals. The only way to confirm neither has changed is to check both. It works like a garage door opener. 4 pins must match each other. On the remote, this is usually found where the battery goes. You will see the 4 pins. Up or down is the only option for each pin. That was easy. The hard part is getting to the receiver in the fan. At the ceiling there is a cover for the wires. 2 to 4 screws hold it in place. Remove the cover and you will see the receiver unit...probably stuffed in there very tight. Carefully remove the receiver to expose the pins. Check that they match the remote sequence. If they do not match correct to match and all should be good. If they match and the battereis are fresh, the remote or the receiver went bad. In which case you can get a universal, even by Hunter Fans at Home Depot or Lowes will work. Color match the wires if you are a DIY'r. Feedback is appreciated if this helped or not.
Jun 30, 2010 | Quorum 73000 Remote Control
Quorum ceiling fan
Try this site:
Jan 10, 2008 | Quorum Ceiling Fan - 138882
Quorum Ceiling Fan - 138880 Logo
130 people viewed this question
Top Quorum Dryers Experts
Dan Webster
Dan Webster
Are you a Quorum Dryer Expert? Answer questions, earn points and help others
