Question about Danby 17 in. DDW1802W Designer Series Built-in Dishwasher
My Danby Silhouette dishwasher is showing error 004 and we can't find the manual. Can you tell us what that error is and how to fix it? This is the stainless steel unit (outside door and all inside are stainless),
SOURCE: Danby ddw2406
I called service. Too much water. The extra water from the pot tripped the overflow mechanizm. It has a float similar to a toilet tank. Pulled the machine out 1/2 a foot on the right side at the level of the door opening, behind the insulation you with find the flood mechanizm. Mine had two rbble plugs. Pulled off the lower one. About 1/4 cup of water drained into a low bowl. Cap put back on, pushed it back under the sink and back in business.
Next time dump the extra water in the sink!!!!
Posted on Jan 29, 2008
Simple solution. DO NOT spend the money on a tech coming to the house.
This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
Posted on Mar 24, 2009
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
tjshondel
  • 11 Answers
SOURCE: dishwasher has an error reading of 004
Click here to download the manual.
Posted on Nov 05, 2009
SOURCE: want stainless steel front door for dishwasher
There are a couple of ways to do this. The easiest one is to check out www.applianceart.com and they have many different options for "wrapping" the front of your dishwasher. They change it often so if you don't see it, call the company becuase I know they have it.
Posted on Jul 11, 2009
Danby silhouette dwc276bls e2 error solution
Hi There,
The E2 error codes indicates there is an problem with one of the sensors.
Please contact our customer service department for information on repair.
1-800- 26- Danby
Thanks!
Jul 19, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Danby silhouette dpac120061 manual
Try to google the manufacturer and model number, sometimes the manufacturer has a downloadable manual online. Otherwise, you may have to contact Danby to order one.
Jul 15, 2012 | Danby Heating & Cooling
Error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go www.fitness.manualsonline.com or www. retrevo.com
God bless you
May 25, 2012 | Danby Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Jun 02, 2009 | Danby DDW1805W Designer Series...
Error code E 04 was on screen for our Danby Silhouette 12000 BTU Air Conditioner Model DPAC120061 and now it won't run properly
most error codes are to do with the main board or a switch board and ussually need to be replaced. If you have the manual for it they normally have the error codes and there meaning in them. If not in the manual you should ring your nearest repairer and give them the make model and error cdes and they can ussually tell you what it is from.
Jul 22, 2008 | Danby Heating & Cooling
Danby error code 002
I spoke with Danby, and this error indicates the fact that the dishwasher is unable to fully drain. Likely causes are a kink in the hose, hose is too high on the drain pipe to drain, or, the pump motor is dying.
Seeing as mine's been mounted without fault in the same place for 2 years, I think I can tell you which one I have.
Dec 22, 2007 | Danby DDW2406 Stainless Steel Built-in...
Danby ddw2406
Jun 03, 2007 | Danby DDW2406 Stainless Steel Built-in...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Danby 17 in. DDW1802W Designer Series Built-in Dishwasher Logo
1,168 people viewed this question
Top Danby Dishwashers Experts
Batista Saint
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
