Question about Toshiba Satellite A215-S5822 Laptop
Cd/dvd driver not in bios - Toshiba Satellite A215-S5822 Laptop
    Genius:
  • 1,189 Answers
  • Hi, click to open the Computer Properties, by clicking on the computer if on your "Desktop" or click on the "Start Button, in the (right pane) select to open the computer. Check to see if there's a DVD RW Drive (D:) in the "Device with Removable Storage area." If the area is (Blank)? Go to and select All Programs, after clicking on the Start Button; scroll to find the Media Disk Player. You made need to (Setup) your player, just open the Player and select to "Setup / Install, follow all the instructions, remember to click on the Apply and OK buttons when finished, and lastly, restart the computer. "Rating the solution for its helpfulness is appreciated, thanks."
Posted on May 16, 2010
I have problem with my cd/dvd drive of my acer emachines e727how can i download the drivers
check BIOS to make sure drives are listed. If not sure how to get to BIOS screen..Google "how to access BIOS on ( insert name/model )
Jan 07, 2013 | Acer Computers & Internet
Mother board m7sxf no dvd function i need update de bios
before you go updating your bios you should troubleshoot your dvd using every option available
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem and you still want to
http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS
BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
Apr 11, 2011 | Biostar M7SXF Motherboard
Disk drive does not work. Possibly need a driver. What kind of removable drive? Rewriteable DVD written on face. Toshiba Satellite A15 series bought quite a few years back. Windows XP home.
I would go into the BIOS and make sure that the correct drive and drive type is there. Up on the boot sequence, hit F2 and go into the BIOS.
Also, go to the toshiba website download the drivers you need. I do it all the time.
Jan 18, 2011 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Hdd and cd/dvd
One thing you can do is to reset the bios setting by clearing the bios. You will need to revothe battery and remove the jumper CMOS battery cc1 .
Note the setting before removing.Usullay ithe default is pin one and pin two.
One oher thing that you can do is to update the bios version
This is sure it will correct the problem oc cd/dvd.
Here are two links below for bios update try this
http://drivers.softpedia.com/get/BIOS/Msi/MSI-K8MM-V-Bios-18.shtml
http://drivers.softpedia.com/progDownload/MSI-K8MM-V-Bios-18-Download-45381.html
ok
Jun 24, 2010 | MSI K8MM-V Motherboard
You have to be kidding! I need the non-existant drivers for this drive to enable it to run on any windows or linux computer.
Have you tried the following link?
http://driver-pro.com/related/english/hardware-drivers/?a=12333&gclid=CJLJ9ITZ5p4CFREeDQodOH48NQ&hit=1&l=46
Dec 21, 2009 | Optorite DW-ISD081 8x DVD+R / 4x DVD+RW,...
Samsung writemaster thinks its a cd drive
Has Bios Detect the Same? If so check motherboard/Samsung writemaster update bios/firmware.
If not reinstall DVD driver.
Nov 29, 2009 | Samsung Super-WriteMaster SE-S184M DVD-RAM...
Acer 4520 DVD driver problem
try to update ur BIOS by install this update from here
ftp://ftp.work.acer-euro.com/notebook/aspire_4520/vista/Bios/3632.zip
Jul 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
My computer does not recognize the dvd/cd driver nor does the tray open without using the reset
When you say "dvd/cd driver", are you meaning the dvd/cd rom tray, or the actual system driver?
Nov 28, 2008 | Acer Aspire 3000 Notebook
LG GH20
did you get and cd along with the drive from where you bought it ??
try to see in that ..the driver must be surely present there....
btw what is the operating system you are running on your dell...most of the operating system automatically detects any hardware changes....
just also see in bios whether your drive is detected at start up.
Sep 14, 2008 | LG (GH20NS) DVD±RW Dual Layer Burner
Toshiba Satellite A215-S5822 Laptop Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
