My rehana boiler light is flashing on and off the heating is on all the time even when it is switched off
3 Suggested Answers
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
  • 2514 Answers
SOURCE: about a month ago red light was coming on my
Hi check ther pump is not stuck it will be hot to touch
Posted on Mar 02, 2010
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Britony boiler problem
check diaphrapm chageover valve
Oct 30, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
My Worcester Bosch Greenstar Combi boiler digital display has started flashing the temperature then two half-rectangles alternately ... it is not heating the radiators to full capacity - any ideas?
just had same problem.  this apprently happens if the power supply has been interrupted or you switch the power on and off.
• The boiler runs for 15 minutes at minimum heat output to fill the condensate trap, the display (K) alternates between -II-” and the boiler flow temperature. This occurs every time the mains supply has been interrupted.
Nov 02, 2008 | Heating & Cooling
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
