Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Water takes a couple of seconds to come out and not making ice
Water takes a couple of seconds to come out now when placing cup in dispenser. And ice maker is only intermittently making ice. Like it's getting air into the line somehow. The longer between getting water, the longer it takes for water to come out. If I use the water dispenser a lot, ice maker makes ice.
  • Frigidaire Master
  • 4,655 Answers
Check the water supply lines feeding the refrigerator for crimps or hard turns and even if someone put a self taping tap valve as a shut off. They tend to restrict flow. If you find a tap valve remove it and have Tee placed there with a shutoff. It also does not hurt to pre-filter water going to the refrigerator. Lowes or Home Depot have some good in line filters that you just plug feed in one end and supply to fridge on other end. If it had air in the water you would have dripping all the time and noise of air rushing out once the dispenser valve is pressed. I am checking if your model has a filter somewhere. Have someone turn water off and disconnect the water feed from refrigerator and place lin in a pan or container and then have the turn it back on so you can visually see the flow. Disconnect power so if things get out of control water does not cover the electrical parts of the refrigerator. Let me know, Thanks Sea Breeze
Posted on May 16, 2010
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
How do I fix my water dispenser?
The ice maker would fill slowly even if you only have a "dribble".
It sounds as if your filter light may in error and the filter may need to be replaced. Unless the one your refrigerator uses is very expensive I would replace the filter before calling a technician. If that does not solve the problem, try googling for an answer to your question. Others may have had a similar experience and know the
cause and how to correct it.
May 19, 2014 | Maytag Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
No water coming out in the dispenser and to the ice maker
check if water is on,check water line,no kinks,clogs,run water,connect to inlet,turn on water,do you here resevore fill up,place cup to dispenser,90 seconds,no water,check inlet,pluged in correctly,if water resevore didnt fill,replace inlet
Mar 06, 2011 | Refrigerators
Dispenses Ice..but not Water
I have found that when ice hangs up in the door causing the water line to freeze right at the very end of the water line. Remove the ice jam and apply cloth that has been wet with hot water to line for @ 20 sec. with a cup in place engage the water dispenser and please note that the ice plug may dislodge with force due to water pressure in the line.
Oct 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not dispensing ice cubes, only crushed
Yup, do like I did. Clean the caddie of all ice cubes. Place a large water catching tray under the door, and run hot water from the inside where the the caddie holds the ice. You will see large chunks of ice that was freezing up your cube maker. After a couple of glasses of hot water pouring through the caddie, it will defrost and the frozen part will be released. Take off the caddie, and run water through it from your sink. Clearing all ice debris. Replace the caddie. Do not use for 24 hours, and it should run beautifully. Mine did that before it froze up and I cleaned it. You should probably take the caddie off every couple of months and run water through it to keep it clean of frozen debris, make sure its dried off well and put it back, wait overnight. and it should be ok.
This is what I did, hope it helps.
May 30, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
Feb 26, 2009 | Cuisinart ICAPP-4
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
Side by side refrigerator icemaker not making ice. Hotpoint mdl HSS125IFMD Tried installing new filter. Getting water but no ice being made.
I would first try replacing the solenoid valve which lets the water in. Also, how are the ice cube arms aligned? They should be vertical
Jul 04, 2008 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
274 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
