Question about Kenmore 24032\24036 Top Load Washer
How to fix overflowing water problem - Kenmore 24032\24036 Top Load Washer
  • Kenmore Master
  • 8,220 Answers
Here is how it works:
You activate the wash cycle and power goes to the motor and water valve.
So either the water valve or the motor but not both will run. Why? The water level switch has 3 wires. A common hot wire and a wire to the water valve and to the motor. The king of the highway the water level switch is the boss dawg. But is has help from mother nature. A rubber tube is placed at the bottom of the tub. It is connected to that water level switch and air tight. As the water rises in the tub the air pressure inside that tube rises.
Engineers have it worked out where X amount of pressure will determine water level in tub. When that air pressure reach's the determined strength BOOM the switch is forced to click. When it does it kills the power to the water valve and shifts the power to the motor babes. And away we go with wash cycle. So what can go wrong? Sand and sediment get into the inlet of that tube. A hole gets in that tube, vibration makes the tube fall away from the switch, and my fav: pinched tubing from reinstalling cabinet incorrectly(been there done that) LOL
To recap: Make sure the tubing to the switch is tight and secure and free of holes or restrictions. Nothing to it. Here is a video which features how to access the water level switch to check all of the above:
Posted on May 16, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster May 16, 2010
    This one shows how to get into the machine:
  • Dan Webster
  • Dan Webster
    Of course if the water level switch is good the water valve itself can go bonkers and the only way to stop it is to close the faucets and replace the valve.
Coffee maker overflows
Who owns the brewer. Usually the OCS supply does the maintenance. Office Coffee Systems sell and service the brewers...the service if for free. Does it have a label on the side or anywhere. If it is overflowing, is it out of the brew basket in to the pot?...There are a couple reasons for that. Is it a water line model?. If it is a pour over, it is human error. If it is a water line model it is probably a leaky inlet water valve. http://www.pamasco.com/bloomfieldsolenoidvalvesandrelatedparts.aspx
Apr 01, 2014 | Bloomfield Coffee Makers & Espresso...
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
The flow of water starts at a high rate then within 15 minutes it slows to nothing
CHECK TO SEE IF THE IMPELLER IF GOT TRASH IN IT..IS THE STRAINER BASKET CRACKED ? IF SO REPLACE IT ...AND HEAR IS HOW THIS PUMP COMES APART
Aug 03, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Oct 11, 2010 | Ariston Technologies LL64WNA Built-in...
Leaking water underneath waterpump,looks like it's coming out of the overflow. How can i fix this?
if its the overflow it will be a tube that goes to the overflow tank, if its coming out the small hole in the alloy casing under the waterpump, you will need two new seals and sometimes a shaft as well. one seal keeps the water in the pump and one seal keeps the oil in the engine, the small hole is a space between the two
Apr 04, 2010 | 2005 Honda CRF 250 X
Ice-maker water overflowing into the freezer/ice-maker.
Possibly the inlet valve.  If it doesn't shut all the way off it will drip water which will freeze in the chute and cause it to overflow.
Dec 19, 2009 | Sewing Machines
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Apr 21, 2009 | Whirlpool Washing Machines
Whirlpool washer overflowing
Water pump on the washer has gone out. Have it fixed by a technicain. Or if you are a do it yourselfer like me.
Go to http://www.repairclinic.com/
Feb 10, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
104 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
