Question about Whirlpool Duet GHW9150P Front Load Washer
When washer is off water come in washer. - Whirlpool Duet GHW9150P Front Load Washer
    Problem Solver:
  • 17 Answers
Replace the water valve
Posted on May 16, 2010
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Kenmore elite washer little amount of water fills washer
If I am understanding the question, you have low water pressure/volumn when washer is filling? If so, unplug washer. Shut off water at valves. Remove water lines from rear water inlets on washer. Clean debris from screen filters in water inlets or in supply lines. Flush supply lines into bucket. Reconnect water, power, and test.
Jul 22, 2013 | Home
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Hot water does not fill in the washer. The spicket has hot water.
There is an obstruction after the shut off to the hot water hose that feeds the washer. Shut off the hot water, disconnect the hot water hose from the washer, and hold the end in the washer tub. Open the hot water shut off. If now water comes out the problem is in the hose. Replace or clear obstruction. Make sure washer at hose end is in place before reconnecting to washer.
If how water flows, inspect the input hose connection to the washer. Some have a screen filter that my be clogged with sediment or other debris. Clean and try again.
If still no hot water, there is likely a problem with the hot water solenoid valve inside the washer itself. You'll have to remove and probably replace the valve or coil (or assembly).
Mar 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE Adora Front Load Washer
I went to the home depot site and they have various videos that explain about the washer and how it works. This made my understanding more clear as to how the washer works. Thanks!
Jul 25, 2008 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
