Question about Pantech Avantalk Wireless Bluetooth Visor Handsfree Speakerphone Car Kit for Duo C810 Cell Phone
My new avantalk btck-12c mic.does not pickup my voice is there an adjustment ?
    New Friend:
I have a avantalk btck12c car kit buy it calls the wrong number . Do I have to put my contacts into my speakerphone My phone is a iphone3g
Posted on Jun 18, 2013
2 Suggested Answers
  • 95 Answers
SOURCE: Why does my avantalk BTCK 20 flash blue?
The bluetooth suppose to be a signal, and the posibility like the phone to activate it will often precising by the way that the bluetooth is running or working. For me, it is logic!
Posted on Mar 29, 2010
I have new cobra ltd new antannas and mounts can hear but cant talk
You say antennas,I assume co-phased,as long as they were installed correctly&adjusted for the lowest swr reading,we'll assume they are ok.Next step would be the radio adjustments ,there is a switch next to your meter that must be set to s/rf,another switch for cb/pa needs to be on cb and last the knob for mic gain needs to be set at about halfway to three quarters depending your voice level and mic type used..are you using the stock mic that came with the radio,if so you should be able to transmit..look at the meter when you key the mic and talk it should move with your voice.If your using an aftermarket mic such as a power mic,make sure the battery is fresh and the correct type,this may also not be wired correctly for your radio if bought second hand..next step would be taking vehicle w/radio to a reputable cb repair shop or technician to evaluate.Good luck and hope everything works out.
Sep 05, 2011 | Cobra 29 LTD CB Radio
My avantalk btck 10b wont connect to my blackberry curve
Had the same problem. It all looked OK and it found the Avantalk, but it would not 'pair' and kept failing. I decided the problem was probably with the Avantalk unit and wondered if I had paired it with too many other phones so decided to do a 'reset' on it. This is achieved with the Avantalk turned 'on-standby', with the two blue flashes every few seconds. Press and hold the up and down volume buttons for more than 5 seconds, at which point the red and blue lights will flash on and off 5 times very quickly. The unit should then return to its 'on-standby' state again. Switch it off (larger MFB phone button), then on again and then set it into pairing mode (immediately after the Avantalk has come on, press and hold the MFB button again until the red and blue lights are flashing), then go through the searching blue-tooth device and so on again with you phone. It should all work now.
Cheers... Rob.
Oct 15, 2010 | Cell Phones
LifeCam VX-1000 Webcam: i can't get any voice responce. I have checked ev...
If you have a laptop and a webcam you have 2 mics - you need to set your webcam mic as default.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure audio to the chat program
May 17, 2010 | Microsoft LifeCam VX-1000 Webcam
Why does my avantalk BTCK 20 flash blue? if it flashes red that means it needs to be charged but why does it continually flash blue around every 3 seconds once I have it on? Looking forward to hearing a...
Mar 25, 2010 | Samsung Avantalk Wireless Bluetooth Visor...
Dell C521 Mic input permanently connected to Audio out put
Control Panel > Sounds and Audio Devices > Voice (tab) > Voice playback > Volume Button > Advanced Button > PC Spk Mute check box
Apr 15, 2009 | Dell Dimension C521 PC Desktop
Mic socket is not working
hi im josh in cebu phils. may i help you? friend if the problem is your mic socket is not working. try buy a new sound card then put it in the pci slot. it will give you new sockets for audio, mic.etc.at the same time it will give you better audio performance. good luck.
Feb 20, 2009 | Intel D845GVSR Motherboard
Headphones with mic model # na
Hello...
Try this one:
1.Click on Start
2.navigate to Control Panel
3.click on Sound, Speech and Audio Device
4.click on Sounds and Audio devices
another window will appear
click on the Voice tab
on the Voice Recording
click on Volume
there should appear another window
adjust the Mic Volume
hope this helps
Oct 09, 2008 | Computers & Internet
HELOW
hmmm try to clean your phone mic' may be the contact of the mic and the board is dirty or dusty'
you can used a headset w/ mic if you don't kow how to clean and dismantle your phone...
Jan 30, 2008 | Nokia 3650
Might be mike problem(the other person can't hear me)
you need a new mircophone. if u have an old fone u can remove the mic and place it in ur nokia
Sep 24, 2006 | Nokia 3100
Pantech Avantalk Wireless Bluetooth Visor Handsfree Speakerphone Car Kit for  Duo C810 Cell Phone Logo
303 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
