Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
My computer can not find my hard drive
I have Windows 7 and it does not register my FreeAgent Desk. I downloaded the device manager and it can't find the device either. Also, when i plug the external hard drive in it makes a dull buuu sound and then 3 fast beeps continuously . Does anyone know what to do?
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
I have a Seagate FreeAgent Go, 500 GB, sn2GE6NC5Z. My computer crashed and took it in for repair with the seagate. In fixing the computer, the service person erased everything on the seagate drive. Is...
FreeAgent™ Software Version 2.1.600 includes folder encryption. This download is compatible with all versions of 32- and 64-bit Windows. This software may be used in conjunction with FreeAgent DockStar™.
FreeAgent? ' Go Software Download for the FreeAgent? ' Go in case the software has been deleted from the drive
FreeAgent? ' Desk Software Download for the FreeAgent? ' Desk in case the software has been deleted from the drive.
FreeAgent? ' XTreme Software Download for the FreeAgent? ' XTreme in case the software has been deleted from the drive
hope this helps you
Jul 25, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
My Pc's, one have windows xp, the other, with windows 7 Home P, not reconized the External Disk FreeAgent GoFlex Desk of 2 Tb. Please, help us. Thanks
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 18, 2011 | Seagate FreeAgent GoFlex Desk 2 TB USB 2.0...
I accessed my Freeagent goflex 1tb on my laptop the first time. but when i tried to use it again, a display shows that the drive is not accessible. access is denied. what can i do? i'm using windows 7...
Switch off and on your Freeagent, that should cause a driver to be loaded. If no change reset your Laptop. You should also upgrade to Windows 10, since WINDOWS 7 IS NO LONGER SUPPORTED.
Feb 08, 2018 | Seagate FreeAgent GoFlex Desk Desktop...
Seagate freeagent USB hard drive power is not showing. Adaptor is ok.
if windows then go to
Start->, select My Computer, and rightclick, and choose Manage.
now on the left there is disk manager - click it. if the disk is on the list it is working and might just need to be formatet or activated.
Disk Manager: http://www.partition-tool.com/images/resource/windows-7-disk-management2-b.gif
Mar 26, 2011 | Seagate FreeAgent Pro 1TB External USB...
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
119 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
