Question about Microwave Ovens
Kitchenaid KBMC147HSS0 Bulb replacement
I either need 1) the service manual, or 2) instructions on how to gain access to the halogen bulb to replace it.
  • FixRGood Mar 30, 2008
    I know the outer sheet metal needs to be removed to get to the bulb, but I'm interested in a more detailed view of the microwave. I would really like the service manual.
  • FixRGood Apr 07, 2008
    I was able to get this resolved with help from IB4G2008, but thanks for your advice!
  • Microwave Ovens Master
  • 13,433 Answers
The PDF file IB4G gave you
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186038.pdf
Is probably the best 'service' manual out there without buying one from the company if they sell them.
I suggest you go with that one
heres the link again
It might be a little harder not to have step by step instructions but you wont need to take the whole thing part.
Shouldnt be too hard, in the end these devices are quite simple.
If you need more asistance, let me know. Good luck.
Posted on Apr 02, 2008
    Guru:
  • 1,894 Answers
Is it ok if i tell you how to get acess to bulb??
i wont have a service manual
  • dewan nafees ahmed Apr 02, 2008
    Getting inside a microwave oven
    You will void the warranty - at least in principle. There are usually no
    warranty seals on a microwave so unless you cause visible damage or mangle the
    screws or plastic, it is unlikely that this would be detected. You need to
    decide. A microwave still under warranty should probably be returned for
    warranty service for any covered problems except those with the most obvious
    and easy solutions.
    Unplug the unit! Usually, the sheet metal cover over the top and sides
    is easily removed after unscrewing 8-16 philips head or hex head sheet
    metal screws. Most of these are on the back but a few may screw into the
    sides. They are not usually all the same! At least one of these includes
    a lockwasher to securely ground the cover to the case.
    Note that on some ovens (I've heard that some Sharp models do this), there
    may also be one screw that is slightly longer than the others to engage a
    safety case interlock switch and prevent the oven from getting power if it
    is not present or one of the shorter screws is used in its place.
    So, with the cover removed, nothing is powered inside (which is a good
    thing for safety!). But when the cover is
    replaced with the screws in random locations, there's a high probability
    that the oven no longer works at all. Kind of like Russian Roulette.
    And, if it's then taken to a service center, they will know someone has
    been inside. If less than entirely honest, they can make any sort of
    claim they want as to what might have been damaged even if all you did
    was remove and replace the cover without touching anything inside.
    "The repair will be $195 because you blew out the touch panel by removing the
    cover."
    Therefore, it is essential to make note of any differences
    in screw types so they can be put back in the same place. The cover will
    then lift up and off. Note how fingers on the cover interlock with
    the main cabinet - these are critical to ensure prevention of microwave
    leakage after reassembly.
    Please see typical microwave oven electronics bay
    for parts identification. Not all ovens are this wide open. If yours is a
    compact unit, everything may be really squeezed together. :) Details will
    vary depending on manufacturer and model but most of the major components will
    look fairly similar to those depicted in the photo. Note that for this model,
    the oven lamp is actually inside the electronics bay right next to the high
    voltage on the magnetron filament - light bulb changing here is really best
    left to a professional if you would otherwise not go inside!
    Discharge the high voltage capacitor as described in the section:
    safe discharging of the high voltage capacitor
    before even thinking about touching anything.
    A schematic showing all of the power generation components is usually
    glued to the inside of the cover. How much of the controller is included
    varies but is usually minimal.
    Fortunately, all the parts in a microwave can be easily replaced and most of
    the parts for the microwave generator are readily available from places
    like MCM Electronics, Dalbani, and Premium Parts.
    Reassemble in reverse order. Take particular care to avoid pinching any
    wires when reinstalling the cover. Fortunately, the inside of a microwave
    is wide open and this is not difficult. Make sure ALL of the metal fingers
    around the front edge engage properly with the front panel lip. This is
    critical to avoid microwave emissions should the waveguide or magnetron
    become physically damaged in any way. Confirm that the screws you removed
    go back in the proper locations, particularly the one that grounds the
    cover to the chassis.
    Genius:
  • 3,587 Answers
Hmmm..ok...let's try the service manual, first, shall we?
Posted on Mar 30, 2008
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 05, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave bulb replacement
The oven will need to come down from the wall so the outer cover can be taken off. Then you'll see the light socket(s).
It's recommend due to the weight and awkwardness of the oven that two people do this job.
If you don't still have your installation instructions, you can download them here, but you should use you full model number, as opposed to the base KEM378.
This uses a fairly common halogen bulb, but I'm not sure of the wattage. It should be marked on the bulb or on a tag near the reflector.
Aug 30, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
the question was in two parts, service manual, and also how to open up to get at the bulb..check the links again on the solution
Mar 30, 2008 | Microwave Ovens
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
