Question about Sta Rite Pool & Spa
Turn on heater and green lights Aux 1, Aux 2, pool on and Spa on lights illuminate. Stays that way. Nothing happens. No red LED
  • 12,061 Answers
Because some types of spa heaters heat water slowly, it can be difficult to determine if the heater is working properly or at all. Before you call in a professional, take a few minutes to troubleshoot your spa heater and see if it is working correctly. Taking a few minutes of your own time can save you a great deal of money, particularly if you can either target the source of the problem or even repair it yourself.
Difficulty: Moderately Easy Instructions
Give your heater the appropriate amount of time to work. If you have a 120 volt spa heater, it is only going to heat cold water up at a rate of about two or three degrees per hour. A 240 volt heater will heat water at about six or seven degrees an hour, so don't expect miracles. If your spa has been out in the cold and you expect it to heat up in only a couple of hours -- that just isn't going to happen.
Make sure both the heater and the pump are on. Heaters can only heat the water if the pumps are working. After all, the pump sends water past the heater, and the heater heats up that water. If you have merely turned on the heater but not the pump, your water won't heat up. Worse, if you turn on the heater but haven't filled up the tub, your heater will burn itself out in seconds.
Check to see if this breaker has been broken. Your heater will be plugged into what is called a GFCI switch, essentially an outlet with an automatic breaker built in. Test it and push it in. If a breakage was the problem, then your heater will now begin to work. If the GFCI switch keeps breaking every time you reset it, the chances are that the element in your spa heater has burned out. If you are mechanically inclined, you may be able to replace a spa heater by yourself. But truthfully, with spas and electrics like this, it's better to let the pros handle this sort of job. http://discountpoolsupplies.com/technical/pool-spa-heater-troubleshooting.htm
above is a Troubleshooting link, as is the link below, the link below is quite exhaustive in troubleshooting. http://ezinearticles.com/?How-to-Troubleshoot-a-Hot-Tub-Heater&id=3603997 below is a install manual for a Spa heater etc. use this to gain an understanding of how it all works and goes together, this will give you valuable insight, as to what can go wrong and how to isolate any problems. Please BE CAREFUL, you are dealing with the MAINS Voltages.... http://www.raypak.com/uploads/6000.52AG.pdf
If you have ANY doubts, please call a professional, then you can get a "Quote" for any prospective repair, and you can then make an informed decision as to what to do. good Luck.
Posted on May 16, 2010
Why is jandy rs6 solar always on
assign the solar in the setup to a aux power the lights from the aux that you assigned
Jun 22, 2014 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Hello, I have pentair minimax 250 pool heater. When turning on the temperature, ddtc cycle to off. Nothing happen, no clicking noise, blower doesn't turn on , no error code on LCD. No led light in the back...
check main power supply for proper voltage, check primary and secondary sides or transformer, 24 vac getting to display screen???? 120 vac getting to blower???
Nov 27, 2013 | Pool & Spa
Sta-rite Pool heater boot probem
bad temp sensor heater isn't reading to go on
May 14, 2012 | Sta Rite 333 Btu Natural Gas Heater...
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a purex triton 300 pool heater that will not turn on. The power is on and there are no red lights. It is all green. The AUX green LED light is also on (don't know if this will help). I tried...
red light is calling for heat check control unit for heat enabled if ok see if heater runs with firemans switch jumped if ok control if not check safety circuit
Sep 11, 2017 | Pentair Pool & Spa
Just changed the thermisor and now the heater won't turn on. 4 green lights come on the control panel: pool on,spa on, aux 1 and aux 2. the underside has 3 green led lights lit and one red for cr21.
If all you did was replace the heat sensor check to be sure that you didn't losten any other wires on the header and on the board. Often when you pull the board for inspection you can pull other wires without knowing. Also be sure your baskets and filter are clean. Good luck.
Dec 07, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pool & Spa Logo
75 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
