Question about Whirlpool Dryers
Dryer with no heat. Whirlpool HD Super Capacity
Dryer with no heat. Whirlpool HD Super Capacity Gas Dryer -model LGR5636EQ2
  • 184 Answers
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Posted on Apr 10, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore 70 Series Dryer Won't Heat
first check your breaker, turn it off and back on.
Posted on Jun 28, 2008
danromarris
  • 101 Answers
SOURCE: dryer does not get hot
Most likely your heating element has gone bad. This will happen from a number of different things ranging from just plain age to clogged vents causing it to overheat and go out. Also with a gas dryer your thermostat may be bad. The thermostat tells the dryer when to release the gas and ignite the flame to heat the drum. This would be my first suggestion on what the problem is. There is also a thermal fuse on your dryer that may be the problem but I really think it's the thermostat. It's hard to say without hooking a volt meter to it to find where the current is stopping but these would be the most common causes. It's always a good idea to have your vents cleaned out at least once a year and if you have a long distance between the dryer and the vent outside get the entire hose cleared out yearly. This will save you money in the long run on parts and save you from any fires. With gas dryers, I have seen it a few times in homes, the lint catches fire due to the open flame and does a lot of damage.
Do try out the thermostat first, it shouldn't cost you but around 20 dollars for it. If you open up the back panel of the control panel you will find the wire diagram and it will show you where the thermostat is located. Do make sure to unplug the dryer first though. Trust me, 110 volts of electricity is not a fun feeling for anyone, I know from experience. If you have any other questions let me know. I hope this helps you out enough to get this fixed, I know what a pain it is to have your dryer out. Good luck.
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Posted on Feb 09, 2009
SOURCE: whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Posted on Oct 05, 2009
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My gas dryer has no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][[]][
Aug 07, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
DRYER WON'T HEAT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Smell gas coming from whirlpool duet gas dryer. Its not the gas line.
Hi, Often times that is because it is not lighting right...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
