Question about Masterbuilt ESQ30B Smoker
Wont heat we have ckeck everthing.it wont heat////
  • 2 more comments
  • Anonymous May 25, 2008
    Temperature is rising on the digital thermometer, but the element is cold.
    Yes, we have used our twice with no problem.
  • trixter62 Jun 02, 2008
    have used smoker 3-4 times and loved it, got ready to use it again, the digital thermometer works normal, but the element does not heat. do i need to replace the element?
  • amigo1 Aug 02, 2008
    I have used my masterbuilt smoker 4 times. Today I turned it on and heated it up to 230 degrees. I opened the door and put in the ribs and it would not get over 170 degrees.
Same thing happened to me. I talked to Masterbuilt tech support, they said it needs a new heater element, which is > $100. Hope that you're still under warranty...
Posted on Jun 23, 2008
  • 32 Answers
Need more info. did it use to work? try taking off the access panel to see if something is lose or looks burnt, possibly a circuit breaker inside the unit or house has tripped?
Posted on Apr 06, 2008
SOURCE:
Why wont my microwave heat when everthing else works?
The unit is not producing microwaves, therefore replace it.
May 03, 2014 | Rival RGST902 - 0.9-cu ft Microwave Oven,...
Everthing works but won't heat
If turntable works suspect inverter (power) or Magnetron itself is bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 2001 sebring 2.7l v6 i have had the starter tested and it passed, just replaced the started fuse, fuel pump relay, and put in a rebuilt pmc unit and it still wont start. you can hear the fuel...
when installing a new chysler pcm you must have it programed by the dealer to learn your venicle by the vin number......butsound like you had the no start before the pcm did you check for fuel presure.......did you ckeck injector pulse....and did you ckeck for spark at coils thats where you should have started......
Jan 24, 2011 | 2004 Chrysler Sebring
Everthing works, but no heat.
this should help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 23, 2010 | Whirlpool Dryers
2001 pontiac grandprix no blower heat/ac
how do i fix my ac/ heater they both wont work not even defrost it use to work only on selection number 5 now it dont work at all we just put a new blower in it today and it still wont come on
Apr 17, 2010 | 2001 Pontiac Grand Prix
Microwave wave stop working everthing works but it wont start up to heat
could be anything, try the high voltage diode first, after that it can get expensive.
Apr 04, 2010 | Frigidaire GLMV168K Microwave Oven
Peugeot 406 hdi turns over but wont start, no lights or gauges work on dash except oil light, climate, multi function screen, stereo, heated seats wont work, everthing else does, lights, windows, electric...
chec the fuse box for bad then do an inspection of the wires for any corrosion/cuts--may hav a module thats bad or computer problem-get a tech that can do a mobile scan
Dec 31, 2009 | 2006 Peugeot 405
Microwave want heat any longer. Everthing else is
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Jul 31, 2009 | Microwave Ovens
The dryer will heat up but will not spin.
ckeck to see if belt has broken.
May 11, 2009 | Dryers
Masterbuilt ESQ30B Smoker Logo
331 people viewed this question
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
