Question about Bose Lifestyle 28 System
Volume will not adjust
The volume level is fixed and will not adjust. The volume numbers go up and down on the unit but the volume stays the same. Any help would be appriciated.
  • 46 Answers
First, I would make sure the Mute hasn't been engaged. If that's not the problem, you might try the following: Press System on the LIFESTYLE® remote control. When you see a preview of audio features,
you can press the Enter button to move into the active list of audio options, and select "Input Levels". Once selected, the menu will run through the gamut of all the input levels. I would make sure that each of these levels is set at Normal. Other selections available are -6, -3, +3, and +6, but these are used to match sound levels of other components so when you switch from one input level to another, they are at reasonably the same sound level. navigate select
Posted on May 16, 2010
Hi, i have a casio privia px-120 and i have a problem with the volume level. it has been stuck in the same volume level and even when i move the volume up it stays the same. ive been wanting to fix it for...
go to halfords and get a can of their eletrical contact cleaner spray, make sure the keyboard has no power spray the volume control liberally, then turn the unit upside down and alow the cleaner to evaporate, you can speed this up with a hair dryer.
Dec 07, 2013 | Music
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
How do i turn my ringer off on my at&t model 1855 phone?
Press the VOLUME up or down button while the phone is idle to adjust the volume. There are seven volume levels and volume off. Each button press will increment the volume level up or down by one level. The screen will show the volume level while you are adjusting it.
Mar 24, 2011 | AT&T ATT-1855 Corded Phone
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
Nov 27, 2010 | Samsung SGH-D900 Cellular Phone
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
Velodyne impact mini going into standby and stays that way? I changed cable but it makes no difference. I had to switch my amp off and back on to get the green light. Can you help? Tks
Here is something to try.
On your signal source, check the owners manual for adjusting out put levels. If it has one for the sub try turning this level up.
Then adjust sub woofer volume on the unit to mach your system volume.
Oct 13, 2009 | Velodyne Audio Players & Recorders
Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | Bose (321GS) System
Cit200
Adjusting the volume of the caller's voice
You can increase or decrease the volume of a caller's voice during a call. There are 5 volume levels for selection.
To adjust the volume, during a call: While the phone is off hook (i.e. dial tone can be heard), press Up or Down.
The display shows the current volume level. Press Up or Down again to adjust the volume.
Still can't find the most comfortable level?
Besides adjusting the volume on the handset, you might also need to adjust the volume on your PC in order to set the speaker to the most comfortable
volume.
To set your handset's ringing melodies and volume:
1. Press MENU.
2. Press Up or Down to select SOUNDS. Press OK.
3. Press Up or Down to select HANDSET. Press OK.
4. Press Left or Right to change the volume level. Press Down.
5. Press Left or Right to select the external melody. Press Down.
6. Press Left or Right to select the internal melody. Press OK to confirm when finished.
Nov 01, 2008 | Linksys CIT200 IP Wireless Phone
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Denon AVR-3802 Receiver
Volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
Dec 03, 2007 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
326 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
