Question about Grilling
Only one side of the burner lights not the other side
One side of the burner lights not the other side
  • Grilling Master
  • 3,315 Answers
Try cleaning the burner out and the orfice
Posted on May 16, 2010
Burner won't light on both sides of burned
The burner is lighting back to the injector on the gas control. 2 things burner out of postion or burner is blocked needs cleaning, you can remove this and clean with air line or small bottle brush.
May 20, 2012 | Grilling
We just put together our Genesis E320 LP Grill. The ignitor is not igniting the far right side of the grill. It does ignite the first two knobs and the side burner. What is going on?
I have a new EP320 and my instructions specify that the ignitor lights Burner #1 and the other grill burners light off of that - Burner #2 second - Burner #3 lights last off of Burner #2.
Gary
Jul 04, 2011 | Garden
One burner of my four burner grill only lights on one side. I have traded places in the grill with other working burners and they work fine in that spot but the one will still only light on one side unless...
If you remove the burner to clean it, did you also check and clean the venturi valve near the open end of the burner, where it fit's over the burner orifice? If not, the venturi is probably clogged. Spiders love to build nest in them. While you have the burner out, inspect it closely for anything you may have missed when you cleaned it the first time.
Hope this helps you and Happy Grilling!!
Jun 25, 2011 | Cal Flame 4-Burner Drop-In Grill
I have a fire Magic A660 drop in grill (natural gas) and when I light the burner (2 of the 3 burners) the flame doesn't travel all the way around the burner. Gas is coming out of all the ports. I can light...
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Mar 18, 2011 | Fire Magic Grilling
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Nov 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Outside grill
I have had this same problem with my 4 burners.
I removed the burners and at the rear of the burner about 4 holes down is a canal that runs to the right side. I cleaned this canal with a paper clip and now my burners on the right side are burning.
Hope this works for you.
Aug 27, 2008 | Jenn-Air JLG7130A
Jenn Air Pro Style gas range - ignitors on 2 burners (same side) click but don't light
I had a problem in which only one burner refused to light with the electronic ignition, even though the same ignitor (they are shared) would light the rear burner on the same side, and the problem burner would light with a match. On inspection, the spark occurs at a central point and there is a tube which apparently leads gas from each burner to the ignitor. There are two groupings of 3 holes each on the sloping part of each burner, facing toward the ignitor. After lighting both burners (the front one with a match), I saw that the lower group of 3 holes had tiny flames on the burner that worked properly, but not on the other. I carefully cleaned each of these holes with a small pin, and the problem appears to be solved.
Apr 27, 2008 | Jenn-Air Kitchen Ranges
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Grilling Logo
139 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
