Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
You need to press the reset butten every 10 hours
It has all new electricial parts
  • 349 Answers
If you have to keep resetting it the thermostat maybe going bad. They are not to costly maybe around $15 dollars.
Inspect the element's wiring and make sure that it look's intact and no burnt look to it. They can short out and trip the reset button also.
Turn power off and disconnect the thermostat one wire at a time and reconnect to new one. You could draw yourself a diagram of th ewiring pattern to make sure you wire it back up correctly.
Posted on Jul 03, 2010
Why does my titan n- 120. why does the reset butten keep tripping?
May be over heating or a short in the wiring.
Jan 18, 2018 | Water Heaters
Blown internal fuse need replacing location required
didnt specify make or model--generic answer --most hot water heaters dont have a fuse usually a circuit reset button that you can press with out removing access panel ---test the heating elements one or more faulty -or thermostat if constant reset
Sep 06, 2016 | Water Heaters
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
Reset button on water heater keeps tripping
Need a new thermostat to keep the unit from tripping
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Is there a reset code for error 13
There is a four hour reset, however that will not fix your problem. You need a new burner assembly.
Mar 26, 2012 | Rheem EcoSense by 4.2 GPM Tankless Water...
No hot water
test the thermostat and the heating elements --also there are resets that can pop push and make sure they have reset
May 17, 2017 | Water Heaters
Hot water tank - Bock model 51E Was working perfectly until a couple hours ago and then stopped. I have a red light indicator on and I've pressed the red button reset and the motor started up for...
Call service technician.
Call Boch Phone: 608/257-2225
http://www.bockwaterheaters.com/technical/engineering.html
I don't see a service manual posted on internet.
Without a service manual showing ohm-readings for testing different parts, you are left guessing which part is problem.
Most water heater manuals today recommend yearly service to catch up on most causes for failure including air in fuel line, dirty or corroded burner parts, defective sensor, loose connection, etc.
Jul 30, 2011 | RTO Bock Water Heaters 51E 50 gal 152,000...
Breaker is tripping off every 20 min i know amp are right plz adviced me how to fix
need to know which breaker- house ele. panel breaker, which should be a min. of 50 amps,or the element breaker located inside either the upper or lower cover. If it is the element breaker/reset switch, this can be changed with great ease. Turn the power off and the ele. panel, check with a voltage meter to make certain power is off at the unit, loosen or remove the wires- making sure as to location of wiring, remove the switch and replace, reconnect wires, turn breaker back on,and you should be ready to go, This is assuming you have a 50 amp breaker in the electricial panel.
Nov 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
69 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
