Proview PL2230wdbi blinking led
I have a proview PL2230WDBi lcd monitor and when i plug it into my computer via dvi the power light blinks orange with blue occasionally.....when i use VGA i get a white screen..unplugging it doesnt do anything else...the light still blinks...unplugging it from power doesnt help either (when i plug it back up it starts blinking but only when i plug video into it) ive tried it on several computers with a variety of video cards...none work with this monitor
Riziel
  • 116 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
You need to replace the power supply! I work with these all of the time, the most common problem with thes montiors is the Power supplies do no generate enough charge to power it up to display an image! If the Power supply does not work I would look into getting a new monitor because then it is truly involved! Bad inverter, or blown LCD. I speculate that if your not getting any video after trying the new cord. replace the monitor! Sorry!
Posted on Nov 26, 2007
SOURCE: Proview 900w
push the button on the monitor labeled auto. it'll fix it.
Posted on Jan 04, 2008
  • 6 Answers
SOURCE: Proview 700P power problem
Probably a bad inverter board.
Posted on Feb 10, 2008
SOURCE: proview 15" tft screen vga cable
model ?
e-mail ?
I have !!
Posted on Mar 17, 2008
SOURCE: Proview PL716s computer monitor
I opend up the monitor and found that some of the capacitors on the power circuit are bulging. I'm pretty sure that is the problem. I just ordered substitute capacitors and will replace the broken ones with them when they arrive. specs for equivalent capacitor: 470uF 25V 105C
Posted on Apr 08, 2008
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Proview monitor blinks off
the CCFL (Cold Cathode Fluorescent Lamp) is failing.
Nov 22, 2009 | Proview Computers & Internet
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Oct 17, 2007 | Proview PL926WBi 19" LCD Monitor
Doesnt power up
Most common problem is inverter board.
Dec 23, 2006 | Proview PL 566s 15" Flat Panel LCD Monitor
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
