Question about Asko W6641 Front Load Washer
What can I check on or do when getting a water
What can I check on or do when getting a water outlet fault message on Asko w6641
    Brigadier General:
  • 4,090 Answers
Check the filter basket that catches waste from the washup. Also follow the outlet hose ( usually winds through cupboards to the sink outlet. ) and see there are no kinks in it from articles being pushed against it.
If these are OK it may be that ther outet valve is jammed and this will require a tech, as the whole casing will need removing
Please rate my help++++Thankis for using FIXYA
Posted on May 15, 2010
Testimonial: "Great, thanks for your help"
Water outlet Fault
Hello donvidon,
Here you can find a manual of your W6641.
http://www.askousa.com/pub/manuals/washers/prior/English-W6641-W6661_QSG.pdf
May 29, 2008 | Asko W6641 Front Load Washer
Getting f3 error message checked drain pump removed a coin last night re ran cycle empty still not draining ive had this message in the past and emptied drain pump and its always worked the pump is turning...
Here is an extract of my guidance notes on checking filter and motor. Try the last paragraph in particular-
POWER OFF FIRST
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 11, 2011 | Asko W6441 Front Load Washer
We have an f2 error cleaned pump and how do you open front door with error
Hello, welcome to FixYa.
There is typically a drain filter in the pump as you know, however there should be a door lock release on Asko built machines...including the W600 series.
This is the typical procedure for machines of the past 10yrs. or so...
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Good luck.
Regards,
Macmarkus :)
Jun 21, 2011 | Asko W6641 Front Load Washer
Asko w6041 wont stop dispencing water
Hi
Your problem is most likely the fill solenoids.
Often, grit, sand and other 'stuff' in your water supply will cause the solenoids to stick open.
To repair, pull the washer away from the wall, so you can access the area where your water hoses attach to the washing machine. Turn the water off.
Disconnect the water hoses, allowing them to drain into a bucker. Identify the screws that go from the back of the washer into the item that the hoses attach to. Remove those screws and disconnect the hose(s) that go into the body of the washer. Remove the solenoid unit. Purchase a new solenoid.
Reverse the removal procedure.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Asko W6641 Front Load Washer
Water outlet fault. The door wouldn't open, so I drained the unit and then the door opened. I cleaned some coins out of filter and tried again. Same fault, water outlet fault.
Hello and welcome to Fixya. With the Asko washer it is possible to have some coins and debris up in the hose which goes from the tub to the pump as well as downstream of the pump in the drain hose, it is a pretty small diameter and quarters, nickles, dimes and pennies can block it up entirely. It will require a very thorough check. You may in fact have a damaged pump as well. If you watch the pump impeller it should spin freely, if it just sits there with the impeller moving slightly back and forth it is faulty. In any event you'll need to either phone in a pro or remove the pump and hoses ( which are held by one-time clamps ) which will require installing new hose clamps and removing the lower service/access panel. Depending on the actual model of Asko washer you have the process of doing this will vary. Let me know how you make out or if you require further assistance. Thanks for visitng fixya, please rate this info accordingly or please let me know how I can help additionally. Good luck. Macmarkus :)
May 25, 2010 | Asko Washing Machines
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
Asko W640 water outlet fault
If you get the water fault after checking the lower drain, you may need to remove the drain hose in the back. Usually there is a dime in the hose or the hard part right before the hose.
Sep 11, 2008 | Asko W640
Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
Apr 06, 2008 | Asko W6461 Front Load Washer
Asko W6641 Front Load Washer Logo
255 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
