The disc keeps ejecting. The machine reads- open- then I insert disc, close door- machine reads-reading- then opens the door by itself and says-open again.
    Brigadier General:
  • 4,090 Answers
The disk is either dirty ( use a disk cleaner) or damaged
Please rate my help++++Thankis for using FIXYA
Posted on May 15, 2010
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
My xbox is not reading any of my discs. it just reads open tray. when we close it again it says reading and then goes back to open tray. can you help?
Hi,the most common reason for the Games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 30, 2010 | Microsoft Xbox 360 Console
Opens and closes repeatedly
hello,
The most common reason for the player opening and closing itself is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your player, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
Hope this helps...
Jun 01, 2010 | Apex Digital AD-1125 DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd drive door will not open. when opened manually and disc inserted door will not close automatically and will not read a disc
Is there any power to the drive? IE is there a green light on the front when trying to read the disk?
It may not have the power in, or may have blown a power circuit.
IF it was just the door not opening and the unit has power, i would suggest the little rubber band is having issues and not opening or closing the door.
Dec 18, 2008 | Computers & Internet
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Oct 22, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
