Question about Keurig Platinum B70 Coffee Maker
This morning my keurig pumping the water onto the
This morning my started keurig pumping the water onto the counter from the bottom of the machine. Any ideas?
  • Anonymous Mar 19, 2014
    my keurig's power light stopped working and there is water leaking on my counter top under the keurig
    Sniper:
  • 92 Answers
Yep... you goto take the metal bottom off and see if the small ty-rap broke off the translucent hose... you can replace it with a Panduit 4" ty-rap... the ones that Keurig uses are smaller and can use to be beefed up... there are 2 hoses coming off the motor... one from the watter fill tank and the other going to the main water tank... Could be anywhere in that path...
Posted on May 17, 2010
I have a Keurig B70 that worked perfect till this morning. It quit despersing water ,what can I do?
I would start with the basics. Get the quick start manual and follow the instructions. If that does not work then the pump or controling circuirty has failed. I have attached a link for the quick start guide.
Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
You can also contact customer service at: 1-866-901-BREW Keurig Platinum Single Cup Brewer Quick Start Guide ManualsOnline com
Mar 02, 2015 | KUERIG Keurig Platinum B70 Brewing System
Keurig Leaks Water Before Brewing
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
Feb 16, 2014 | Keurig B60 Coffee Maker
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
Water does not go through the k cup. when the cup is placed in the coffee maker and the lid is dropped down, the needles punch through the cup at the top and the bottom. the water spills over the top of...
Yup... the bottom needle is plugged...Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 24, 2011 | Keurig B60 Coffee Maker
I pressed the button to turn on my Keurig this morning and it did not turn on. What might the problem be? It worked fine yesterday.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 25, 2011 | Keurig B60 Coffee Maker
My keurig won't even turn on. We unplugged and replugged but still nothing. The outlet does work, so don't know what to do. Is there a fuse or something simple that I could try. The Keurig is about...
heatman101
Aug 13, 2011 | Keurig B60 Coffee Maker
Yesterday morning my maker worked just fine, but this morning it will not power on. Need my coffee.
heatman101
Aug 08, 2011 | Keurig Elite B40 Coffee Maker
Morning We have a Keurig coffee maker but I don't see a model number. The machine won't turn on
heatman101
Jul 22, 2011 | Keurig B60 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
1,170 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
