Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on May 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poor Suction My Dyson DC17 is having very weak suction. I have checked the areas that I can easily access and can't find a clog. What could be causing this?
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on May 31, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
0
Helped
31263
Points
132
The flexible hose between the beater bar housing and the connection to the dust bin might have come loose or has a hole in it. Check this hose for your low suction problem.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on May 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
14316
Points
10
You can download the manual here: <a rel='nofollow' href="http://www.pdfsnatch.com/2013/04/dyson-dc17-manual/">Netgear n300 manual</a>
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
789
Points
Most Dysons, including the DC17, have a "valve pipe assembly" that ports the suction to the floor or to the handle accessories; depending on the tilt of the handle. This may be worn, or the seal is not working. It can be easily popped out and checked. Replacements run about $10 plus S&H.
Jeffrey Spahn
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Aug 06, 2010
Jeffrey Spahn
Expert
Level 2:
New Friend:
Answers
105
Questions
Helped
28924
Points
263
You'll also want to make sure your main filter isn't clogged because your bottom gasket inside the dust bin isn't upside down
Very little suction at beater brush.
Hey, this is Leland with Crucial Vacuum,
If the brush bar is not working properly there may be several reasons.
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction.
You can purchase replacement parts for the DC17 direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=dc17
4answers
I turn on the vacuum and it does nothing but when i put the brushes down is turns on and the brush motor runs.....but the suction motor won't do anything.......help!
You have power so it can't be the switch or power cord. It is most likely the motor or the cord from the switch to the motor that is the problem. Start by checking these areas first.
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
When I vacuum carpets the hose suction does not stop and the main brush area is losing suction because of it.
I'm sorry to hear you're having difficulties with your DC17. If your machine continues to have suction through the wand after you've reclined it into the vacuuming position, a blockage may be jamming the changeover valve. To check for this, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
This should resolve the issue, but if you'd like any further assistance or advice, please call us free on 1-866-693-9766, or email us at [email protected]
Best wishes,
Jack
Dyson Online Customer Support
No suction. upright position shuts off unit. Turning off brush bar shuts off unit. will only run in floor position but has no suction. no clogs found.
From what you've described, it sounds as though you may need to wash the filter. This video guide from the Support section of our website shows the correct way to do this:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Although you've found no blockages, it's definitely worth checking again to ensure nothing has been missed. This simple step-by-step walkthrough shows all the areas you should inspect:
If you've followed these steps and are still experiencing difficulties, please get in touch with us free on 1866MYDYSON, or email [email protected]. One of our experts will run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
2helpful
I have a blockage in the wand and don't know how to remove it. No suction
Disassemble Your Dyson Animal so you can access the area around the wand. If the block is in the wand itself, you can clear it by passing something through it (such as a broom or mop handle).
Blocks in other piping and outlets can be removed by hand.
Beauty of the Dyson Animal line is that a homeowner can find and fix problems easily.
You can download the manual from here: http://www.manualowl.com/m/Dyson/DC17/Manual/205779
I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
Dyson DC17 All Floors Instruction Manual:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 • Vacuums
1helpful
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
1helpful
2answers
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
