Question about Yamaha RX-V490 Receiver
Receiver cuts out after a few minutes
I have a Yamaha I have had for several years. I turn it on and it works for a few minutes then it clicks off and will not come back on. I can run the test and the speakers make noise but there is no sound otherwise.
I like this system and do not want to replace it can you help.
Naomi
    Brigadier General:
  • 8,546 Answers
So are you saying it needs to be playing for awhile before it dies? The Test Tones are brief and appear to work. I'd say you have a heating issue or a component within that malfunctions when its strained.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 21, 2011
Not working anymore after electricity cut
Could be simply an open internal fuse
May 15, 2017 | Sony STR-DG820 Receiver
The unit will turn on, however, sound doesn't work and no buttons work on the unit or remote. like it's frozen.
Unplug the receiver for a few minutes, then plug it back in. If you still have a problem, post a comment and I can help you further.
Aug 04, 2009 | Yamaha RX-V363 Receiver
Sound Cutting Out
Somthing is tripping th amp breaker...
Try unplugging it for several minuets & see if clearing it helps..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Teac AG-780 2 Channels Receiver
Yamaha RX-V2095
Hey there! Nice receiver :0)
Sorry about your troubles. I've been where you are with an Rx-V2600. Would turn on and after a few seconds click off. I thought maybe it was bad wiring but even completely disconnected it would still do it.
I took it to a shop and I was told it was a bad channel. Luckily I mentioned I had a Denon receiver that had stopped working and he said he would take that as payment.
He fixed the Yamaha and it's been working for years.
If you search the internet you should find a local authorized Yamaha repair center. I would take it there. They marked charge like a $30-$50 fee to look at it but usually they apply that towards the repair.
Mar 05, 2017 | Yamaha RX-V630 Receiver
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
Htr 5590
Mine played for about and hour then cut off. It would cut off randomly after this hour. I initially thought it was overheating but after seeing other people had it happen after immediate turn on it must not be the case. Intermittent problems like this are difficult to troubleshoot which is why I came to this site hoping someone had found a simple answer. I am a technician and will have to do it the hard way. When I find the answer I will report my findings to this site.
Apr 14, 2008 | Yamaha HTR-5590 Receiver
Power interuptiions
The unit is most likely getting too hot. Check your speaker cables for frayed wires that may be touching each other. The amp will continue to work, but work much harder into a lower impedence load. Over time this will damage the amp. If the cables are OK, try running the amp with the speaker wires disconnected. If the unit still behaves the same way, there is a problem internally with the output section that should be corrected ASAP.
Dan
Mar 31, 2008 | Yamaha HTR-5990 Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Yamaha RX-V490 Receiver Logo
93 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
