Question about Goodman CLT60AER60 Air Conditioner
Condensor fan won't run.
I have an older Goodman 3 ton (15 yrs old) and the condensor fan blade cut through one of the fan wires. The wires on this unit run through a piece of plastic pipe that is position above the fan blades. That pipe and wires fell onto the blades and one of the 3 wires was cut. I was easily able to splice the wire but the fan still won't work. Could the cut have caused something else to go bad?
I have twin units and the other one runs fine, so if needed I can swap parts to confirm whats bad. Just need to know what to try.
Thank you!
    Novelist:
    Champion:
  • 246 Answers
The fan motor runs on 220 volts (2 - 110volt legs and 1 - common - hence 'three wires') - and when the wire was cut I suspect it cut thru a 'hot' leg - leaving you with the other 'hot' leg and the 'common,' effectively putting - 110 volts to your motor - which 'burned it up,' electrically.
Another possibility is that when the wire was cut - it could of 'cut your fan capacitor' out of the circuit - but I tend to doubt this because the internal overload should of protected it.
I'd change the motor.
good luck!
Posted on May 16, 2010
  • icemelts
    icemelts May 19, 2010
    Usually, three copper wires come into the home. Two are covered in black insulation and one has white insulation. Sometimes one wire is red instead of black. Each black or red wire is called a "hot" wire and has 110-volt AC. The white wire is called the "common" and is grounded at the power station. Measuring across the two hot wires results in 220 volts. Measuring the voltage between a black (or red) and white wire, results in 110-volt AC.
  • 31 Answers
Check the fuse, you may have shorted.. so some mfgrs put a fuse so that you don't cook the circuit board.
Best of luck
  • 2,019 Answers
The 3rd wire is not a common ground but just chassis safety ground.
With 220, there can never be a neutral ground.
The voltage must always be across the two power wires 180 out of phase. So the loss of one wire could never have cause a device to burn out.
In which case it is probably a fuse that blew when the metal blade pierced the insulation.
Easy enough to tell. Just open the splice back up and test for 110 volts to chassis ground or 220 across the two power leads.
Posted on May 17, 2010
Piston size for 3ton indoor coil
if you have a 3 ton condensor it is .074. the piston is sized according to mfg. instructions for condensor
Jun 04, 2014 | Goodman Heating & Cooling
What is the model of a 3 ton condensor
the model you have in your question is a 3 & 1/2 ton condensor.
Jun 04, 2014 | Goodman CKL42AR42 Air Conditioner
Goodman SSZ140481AG, what is it? is it 14 seer or 15 seer? I paid for 15seer but the unit has a decal on it reading 14 seer??? Thanks
It is federal law that each new piece of A/C equipment have the yellow SEER rating.
The higher the SEER, the less electricity the system uses to operate.
You need to follow up since it appears your contractor installed a less efficient/expensive system than what you paid for.
Good luck.
Sep 15, 2013 | Goodman CACF048B2A Air Conditioner
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
Condensor fan runs after compressor shuts off
If new motor is 4 wire verses 3 wire use seperate capacitor between brown wires and don't use terminal on 3 pole cap. If this motor has a white strip on one brown wire you can wire it the old way using only 1 brown wire and tape off the other. Can't remeber this morning which brow wire to use . I need to leave. Goole replacemotor with 2 brown wires for more info or call where you bought it. Sorry got to run.
Jul 01, 2009 | Weather King 12AJA4801AH Air Conditioner
Fan whining and blades not going
Sounds like your compressor outside is frozen up or (locked up) the smell is outside correct? it could also be your fan also in your condensor unit outside the easiest way is to listen for fluid movement (if your freon is moving then your compressor is working and you need to lean toward a fan motor. check to see if you can move the fan blades in the compressor (outside ) if the problem is in the house then approach in the same way with the power to the unit turned off only If you cannot turn it most likely fan motor replacement is in order, and pressure sensors are not letting your condensor run. theres a few things to try hope i have helped .Honestly it probably would not hurt to let a service man look at it anyway, but this way at least you're a little wiser chris
Jun 12, 2009 | Goodman CLT36AER36 Air Conditioner
Condensor fan motor
you have a reversible motor or a two speed motor check the old motor for speed and rotation
Jul 29, 2008 | Goodman CLQ36AR49 Air Conditioner
Open Questions:
See all Goodman CLT60AER60 Air Conditioner Questions
Goodman CLT60AER60 Air Conditioner Logo
125 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
