Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
No picture Tv volume is fine but there is no picture. Red light by power source is flashing red continually.
    Brigadier General:
  • 4,090 Answers
The number of flashes will tell me the fault, however non of the information will be good . That is when this happens it is always a money payaout for major type repair. Some component has an open circuit or a toatal board has copllapsed. Not a DIY either.
The first temporary test you could try is unplug it for 24 hours to see if it will restart. However this is usually tempory and may mnot turn on the next time either and even more damage will have possibly occur.ed.
Please rate my help++++Thankis for using FIXYA
Posted on May 15, 2010
Sony KV29X5U No picture, red light flashes 4 times then out then 4 times etc. Is this worth fixing?
What is the exact model number of the Sony TV? Check if the same issue occurs when connected to a different source device like DVD player or when the TV is not connected to the cable box. Disconnect the connected devices and turn ON the TV to check if the red light still flashes
Sep 28, 2016 | Sony Office Equipment & Supplies
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Red light flashing...no picture. TV not turning
Probably a failed main power supply. There are at least two supplies; one that keeps the remote function alive continuously and the second that is turned on when the set is ordered to operate. The smaller supply is a low voltage circuit and that is providing your error indication.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
