Question about Microsoft Xbox 360 Elite Console
The board of my xbox didn't work.how to repair it?
    Problem Solver:
  • 13 Answers
You have to take it to the place from where you have bought your Xbox 360 and replace the board of your Xbox 360.
Posted on May 16, 2010
I have a Technics PR-305 Digital Piano. I turned on the power it worked when i played it, the next time I turned on the power it didn`t work, can the Electronic board be repaired to work again?
Your best bet would be to contact Technics customer service to locate the best repair shop in your area and to check on the availablity of parts for your specific model.
Jan 06, 2016 | Music
I have a Xbox 360 thats showing 2 red lights. I understand that its an overheating problem with the cpu and gpu. I change the thermal paste, towel trick and reflew it. When I power it up, the fans com
Sorry to tell you this buddy, but i don't even need to see your console to know that it's totaled. First of all, the chips are attached to the board using lead free solder. Lead free solder melts at 217C (443F). You'll be lucky if you can get the xbox to 120C using that method. So no, you didn't perform a reflow. The only reason that works SOMETIMES is because the temperature causes tin whiskers to break down, which are the cause of red ring in a select few cases. Considering that an xbox operates at about 75C, and you blocked all ventilation entirely, you probably broke the 100C threshold. Electrolytic capacitors either melt or explode at 85C. Without capacitors, power cannot flow properly, which explains why the power brick keeps going from green(normal power flow) back to orange (either off or insufficient power). Buy a Xbox slim, and NEVER attempt that again. Apart from being an obvious fire and electrical hazard, you also rendered a machine that may have been repairable into a molten paperweight.
Jan 21, 2012 | Microsoft Xbox 360 Console
I was playing Oblivion on my Xbox 360 and after a few minutes the screen went gray and the sound stopped. I didn't have any rings of death so I turned off my console and tried again. The console turned...
Your graphic card is failing on you, only option is repair your system through either microsoft or a local repair shop. Repairing the graphic card is not a simple repair as its not replaceable.
thanks
www.1RepairStop.com
We Fix Everything
Sep 01, 2011 | Microsoft Xbox 360 Console
KEEP GETTING E74 ON MY XBOX360 TRIED RESETTING COMPUTER WORKS FOR ONE HOUR THEN GRAPHICS DISTORT THEN RED LIGHT THEN MESSAGE E74 HAD CONSOLE FOUR FIVE YEARS
Sounds like a hardware problem. Turn off the Xbox and remove the hard drive, then turn it back on. If you get still get the message, or red ring, then it's not the hard drive. If that didn't work make sure the A/V cable is hooked in securely. If you have a different A/V cable try that one and see if you still get the message. If you do then it's a problem with the hardware and will need repaired. There are several DIY websites for repairing an Xbox but you will need some tools. Or you can contact microsoft and see if you can still get it repaired for free.
May 04, 2011 | Microsoft Xbox 360 Console
Got gears of war 2 all fronts collection entered redeem code for maps and got stupid era so wtf?also its pissed me of as had xbox stolen so tryna replace what i have lost should i contact...
I would contact Xbox Live and explain to them politely how you bought a code but it didn't work. They may suggest that you go back to the retailer but with codes like these it's really hard to prove that you didn't download it and then claim it doesn't work.
I hope I have helped,
Chaz
Apr 25, 2011 | Microsoft Gears of War Triple Pack...
I just got an xbox 360 for christmas, and it's been working just fine. Except that when ever I go to the dash board, my avatar wont show up! And neither will the other user's! Every time I press...
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 05, 2011 | Microsoft Xbox 360 Console
I bought a new xbox 360 driver circuit board and installed it myself, now the game don't work on it. it says i need to install the disk into an xbox 360 system, then a bunch of chinese writing help
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console........
Click here to download repair guide
Dec 24, 2010 | Microsoft Xbox 360 Console
When I put a game into the Xbox, the screen says reading. then "Open Tray" is displayed. Will not play games.
Hi you need to replace the whole dvd drive as the laser is not dropping down to stop scratching the disk, the problem with replacing the dvd drive is you need to get the exact same drive and their are 5 different types but when you do get another drive you need to take the circuit board off your drive and swap this with the circuit board on the new drive, its called the control board,
now the reason you need to put your control board on the new drive is due to the fact that the dvd drive is married to the firmware on your xbox so only that control board will work in your xbox so if you fitted a whole new drive and didnt swap the circuit board over thats on the bottom of the dvd drive your xbox would not play games ever again so you need to put your control board on the new drive to ensure your xbox recognises the dvd drive as being the one from the xbox.
their is no way around this without hacking the drive and doing this will ban you from xbox live so its not worth doing when you can just put your control board on the new drive and have a fully working xbox.
the fault you have is covered by warranty for 3 years so if your xbox is less than 3 years old get on the official web site and request a repair they will then send you another fully working xbox but you wont get much warranty as the one they will give you is a refurbished one. check the date on the back of your xbox to find out if you have any warranty left.
if your going to do the work yourself then use google and search for xbox 360 repair guide and this will tell you how to take the case off the xbox as its not easy to do, once you have the case of getting the dvd drive out is easy it just lifts up and you pull the wires out of the circuit board, you then need to check the make of dvd drive and get the same one then if you take the case off the dvd drive by undoing the 4 screws on the bottom you will see the circuit board that needs keeping with the xbox undo the wires and data ribbons and keep this circuit board as this will need to go on the new dvd drive.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Dec 13, 2010 | Microsoft Xbox 360 Console
My xbox doesn't read discs and when i get disc in the console do scratches on disc. what i do? Sorry my bad English
Dec 07, 2010 | Microsoft Xbox 360 Console
I was playing my game on my xbox 360 and then my brother knocked over my xbox while i was still playing. and then it made a weird noise, i took out the cd and it has a circular scratch. is there anyway to...
please rate this solution as i have a whole page of unrated posts, thanks.
Dec 07, 2010 | Video Game Consoles & Games
Microsoft Xbox 360 Elite Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
