Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Smoking washer washer smells like urning brakeshoes.
  • jthatter77 Apr 17, 2008
    keep braking belts what do i do?
  • Linnea13 Mar 13, 2009
    I just had the washer/dryer installed last week and have done 3 loads of wash with no problem. Just ran it tonight, and it sounded a little bit strange and then the whole house filled with smoke. What is that and how annoying will it be to get it fixed?
Thank you, found problem,
Posted on Apr 01, 2008
SOURCE:
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer smoke and burning smell
washer smoke? Smoke from exhaust? What color smoke there? Please, send us details and features car (year, make, model ane engine size).
Jul 11, 2012 | Cars & Trucks
Smoke and it smells comes out of vents when ac on nissan altima
Smoke from under the hood ?
Smells like burnt rubber ?
Either the compressor or the comtressor clutch is bad so it locks up wen you urn it on and the fan belt is burning..
have the ac system inspected..
Aug 20, 2009 | 1998 Nissan Altima
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Nov 26, 2008 | Maytag Dependable Clean Top MAV5920EWW Top...
Burning Smell - smoking coming out of it
I believe we tracked it down to the pressure switch mounted on the drain pump. The device had a strong electrical burn smell and is positioned where it could easily have smoked the basket. We're putting the washer back into service and if I have a recurrence I will post the information. BTW ... Replacement was simple and the part was $26 including shipping.
Jul 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Weird smell
Probably mildew. They often suggest running a bleach only (no clothes) cycle every month or so with front-loading washers.
Oct 09, 2006 | Kenmore 44102 Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
210 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
