Question about Clarion XMD3
WHERE IS THE AUX INPUT ON THE CLARION XMD3
WHERE IS THE AUX INPUT LOCATED?
SOURCE: clarion xmd3
Yes, there are 2 Red RCA jacks on the back. A $10 cable from radion shack, 2 RCA on one end and a 3mm jack on the other.
Cheap way to do it, there is also a device you can buy from Clarion that will do it for about $90 that gives you more control from the radio.
Posted on Jul 01, 2008
SOURCE: XMD3 unable to select anything but satellite
i have had several problems like that. It is probably one of your controllers especially if you have the old oval ones. Go to the back of the stereo and unplug them, then plug one in at a time and isolate the problem to a controller.
Posted on Sep 02, 2008
elecgooroo
  • 57 Answers
SOURCE: Instaling a Clarion XMD3
clarion website download + print
Posted on Jan 10, 2009
  • 77 Answers
SOURCE: WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
Posted on Jun 21, 2009
  • 51 Answers
SOURCE: Clarion XMD3
This is typically the output IC not working. This can be due to a speaker short. The unit will need to be repaired or replaced.
Posted on Jul 06, 2009
Tell the difference between the Aux input and V-Aux input
'Aux' is a general label for any Line Level analog stereo input like DVD, VCR, TV, DBS, etc. They are usually electrically identical and interchangeable except for PHONO.
V-Aux on this unit is on the front panel for conveniently connecting a video device. It has analog and assignable digital audio plus S-video and composite video.
There is nothing labeled 'Aux' on this unit.
Feb 16, 2011 | Denon AVR-2807 Receiver
Where is the aux input located?
aux, just means Auxiliary, or An Extra, it is any other input or output that the unit has in it, that can be used. There is a "Main" input, and any other ones are considered "AUX" or an extra one as well.
Mar 27, 2010 | Sony CDX-CA680X CD Player
Aux input jack on 2007 honda pilot
If you see and AUX button but don't see the jack then its on the back of the head unit. You need to take the dash apart to pull it out to get the aux jack. Search online for instructions.
Feb 18, 2010 | 2007 Honda Pilot
Cannot get rear aux input source to work on pioneer deh-p6800mp. no option in function to able/disable that function. also would like to know the name of the type of plug that is used for front aux. input...
The type of plug on the front aux is a 2.5mm plug similar to what cell phones use. You need a stereo 2.5mm to 3.5mm adapter, then you can run a chord with a 3.5mm jack on both ends to an iPod or some other type of mp3 player.
Dec 14, 2009 | Pioneer DEH-P6800MP CD Player
Can i use mp3 player with panaconic cg-c1300u?
If your audio system has aux input then buy a compactible cable to connect your 3.5mm output oprt to the audio systems aux input. then change the audio source is Aux input in your audio system and play the audio using our ipod.
Aug 19, 2009 | Panasonic CQ-C1300U CD Player
How do you get to s-video on a durabrand tv, av button just goes from tv, to aux one (rca in back) to aux two (rca in front) then back to tv again?
Check to make sure that your series of set has an S-Video connector on the input panel (usualy located on the rear side of the set).
In most TV sets, the S-Video is shared with video input 1, and or 2.
For example, if the S-Video connector is located at position 1, then make sure that there are no other connectors in the video connector for the base-band video feed. The audio connectors will be okay, because S-Video does not carry the audio.
When using S-Video, the L and R audio, and the S-Connector video input will be used on the respective video input.
Jerry G.
Oct 02, 2008 | Televison & Video
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
My deck doesnt have aux as a source
I enabled the AUX as a source by pressing and holding the menu button (located to the left of the volume knob) then pressing the control knob up till I found the AUX options and put it on AUX2 so I wouldn't hear the audio feedback.
Mar 24, 2008 | Kenwood KDC-MP2035 CD Player
Aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Nov 04, 2007 | Alpine CDA-9883 CD Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
Clarion XMD3 Logo
615 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
