Question about Kenmore 63942 Dryer
Just got the unit from a friend and had to change the plugs from four to three and it turns on but there is no heat. the dryer is less than a year old and worked three days ago.
  • Kenmore Master
  • 2,699 Answers
The only difference is the 4 prong has a ground wire,if you put the white in the middle,the red where it was before on one side and the black on the other side it should work.check the back of the dryer to make sure you have the correct voltage,with a meter set on volts,touch the white and red wire and you should have 110,then touch the white and black and you should have 110.if not you have a problem with a fuse in the house.one fuse runs the dryer and another is for heat but if you have 220 or 240 in the back of dryer something is blown in the dryer.you'll need to check out the thermostats and the heater in the dryer.let me know what you find.your vent line could be clogged with lint and popped the high limit thermostat on the heater box
Posted on May 15, 2010
I have a dryer with three prong plug but need to change it to four how ?
Hi sookie711
Go to the following webpage and it will show you how to connect your dryer from 3 to 4 wires
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 15, 2012 | Dryers
We just bought a Mini Plus B31 coffeemaker and the cord will not plug into a standard three prong outlet. Other appliance cords do plug into the same outlets.
if you have a four pin plug, check that it is not three phase for heavy electrical use. ask your electrical supplier if your house has three phase, if your house had electric storage heating there is a chance it had three phase to balance the electrical supply to the property this can be dangerous so check please (some old boilers were two or three phase years ago)
Jan 18, 2012 | Dryers
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
Landlord wants to know what type of plug is on my dryer. Dryer is in storage. Dryer is about 8 years old. Is there a common type?
It's either a three prong or four prong plug. He'll need to change the outlet to match the dryer or change the dryer plug to match the outlet.
Oct 23, 2009 | Dryers
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
No Heat
no the four wire cord just has an extra green ground wire,the three pong will work just make sure you have the middle wire on the cord on the middle of the terminal block,let me know how you make out-mike
Apr 02, 2009 | Whirlpool LER4634J Electric Dryer
From three prong to four prong
Hello There,
your hooking up 2 Hots 1 Neutral and 1 Ground
240v
you need to consult a electrician for reason that 240 is a very high voltage and will kill you.
your outlet has to match your plug and how its wired into the Panel
Double Pole Breaker 50amp no less
2 hots go to breaker from outlet red / black
1 neutral goes to neutral bus bar in panel from outlet
1 ground goes to ground bus bar in panel from outlet
that equals your four wires
Mar 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer doesn't dry very well.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Why are you talking about it rather than acting on it?
You need service to fix it or perhaps if its old trash it and buy new!NOT MAGIC CHEF!
If you buy for price only you will change APPLIANCES EVERY 5 YEARS!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 63942 Dryer Logo
49 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
