Question about Amana 3.2 cu. ft. Top-Load Washer
Walks all over the room
Less than 4 years old. 2 major overhauls and once again no support from Amana to fix the unit again.
  • Amana Owner Mar 30, 2008
    Hope someone can help....
  • 1,028 Answers
Problems have occured with base and "milk stool" this is main support assembly may also be a worn snubber ..the plastic ring between mild stool and base
Posted on Apr 24, 2008
How much more efficent is this than my 40 yr old janitrol 125000 btu beast
not knowing what you are replacing it with, it is hard to give a reasonable answer ( old sealed units against split system converter ac units )
However if you work along these lines, you will come to a logical decision
First off the old machines had the compressor operation tied to the thermostat setting so the compressor ran full blast until the room cooled to the set temperature. Then it stopped and remain stopped until the room heated up. At this point the compressor restarted and that is the point the the most power is consumed
again it runs full blast until the room again cools and switches off
So you can see that you have a varying room temperature and high energy consumption on start up
Now compare that to inverter units
The compressor is running all the time ( no high energy start ups every 10 minutes or so) but the compressor becomes less efficient as the room cools down
Still running at full rpms but the controls reduce the compressing action--less power to run the compressor--so there is a reduction in power used
The temperature variation is reduced because as the room warms a bit the compressor pumps a bit more gas and doesn't start at full load as per the old unit
Next , the latest units have better temperature / humidity recognition controls so they can be set at night so a room maintains an ambient temperature /humidity so that as the night gets cooler and the air drier you don't wake up freezing
It will even get to the point where you wonder if the unit is working
Lastly you can run the unit at a much higher setting ( 27 Degrees c instead of 24 or less and have the same comfort level as at 24-25 degrees c)
lastly warranty is for 2 years at best and parts will be available for the next 10 years against parts for your old unit
Mar 21, 2016 | Heating & Cooling
Motor failure after less than 5 years
hi there.well its an electrical item after all.assuming that all other reasons has been checked ie(1- power cuts 2- power surge 3- hot room temperatures 4-refrigerant leaks 5-internal bloackages etc...or plain and simple bad luck.ALI
Oct 07, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
Amana Distinction super capacity plus 3.3 stainless great, no vibration, but in the spin cycle it has started to roar, being very loud. Why did this start..could it be the idler roller for the...
You have a tub seal that has leaked and the tub bearing has gotten wet and started to rust. This problem will continue to get worse and louder until the tub bearing falls apart. This is a major repair , the parts are not that expensive to replace, ( about $60.00 )but the labor involved is major. In some cases the washer is replaced for this problem. I also would not recommend you attempt this repair yourself. This job takes a professional about 3-5 hours, and sometimes the seal will leak again anyway. If you do decide to attempt this repair I will try to find you a detailed step by step guide. But, be prepaired to replace the machine if the repair fails. It is a major job. I know this is not what you wanted to hear, but its not a horse so shoot it and get another one. that would be my suggestion.
Michael Anderson
Anderson Appliance
Feb 10, 2010 | Amana Washing Machines
Front loader won't balance on spin cycle. thumps and walks almost every time. Spins ok if empty. This is a new problem (last month or so). Machine is less than 2 years old. Maytag model MAH2400AWW...
The problem may be you might be cloths will be less quantity kindly check the cabinet of the unit and the upper spring is be elongated kindly replace the spring before that check the cabinet any revit has been cutted off
Dec 24, 2009 | Washing Machines
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Wiring for an Amana PTL
That is a stinger leg and you will burn the unit up. 2-@110/ground is what you need.
May 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Clicking noise + not cold enough
my Amana did the exact same thing. I had a reparman come out and he fixed it. There are 2 reason for it. It is either the compressor that needs to be replaced (about 300-500 to fix) or the relay for the compressor (around 100 to fix). once it is fixed remember to vacuum the coils from the back of the fridge once a year to extend the life of the compressor.
Apr 05, 2009 | Amana ARB220RCW Bottom Freezer...
Hums and won't kick on
  1. sounds like a bad cvompressor as long as u bought it before 2006 the compressor should be covered call your loical maytag repair man
Mar 18, 2009 | Amana ABB1927DE Bottom Freezer...
Amana 3.2 cu. ft. Top-Load Washer Logo
57 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
