Question about ViewSonic VX1940w LCD Monitor
I have a viewsonic vx1940w Monitor which will no longer power on. I'd like to take the back off and see if there are any loose connections but there are no visible screws. Does anyone know how to open it?
  • 11,361 Answers
There is no exact instruction, but first thing you have to do is to remove the stand, then starting at the bottom edge of the case using thin flat blade screw driver to pry open the case up and then work your way around the case, you can also look at YOUTUBE, just search for 'how to repair LCD monitor', 'How to open LCD monitor'
Bad caps (leaking/bulging top) are common failures.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 16, 2010
Why does viewsonic monitor vx1940w dvi goes to sleep on windows 7?
Make sure the resolution signal sent out via the DVI is a valid timing signal the monitor can recognize.
May 20, 2014 | ViewSonic VX1940w LCD Monitor
Why
The monitor may be defective or you provided an invalid timing mode to the monitor forcing it to go to sleep mode.
May 08, 2014 | ViewSonic VX1940w LCD Monitor
ViewSonic VX1940w cycles between blue and amber light for a minute before finally syncing
Hello John,
Yes, That is a very common symptom of the beginnings of capacitor failure on the power supply board. The unit uses the Darfon B092-XXX 27-D021625 power supply board which is very easy to repair. There are only 4 capacitors that need to be replaced. Here is a link to a repair kit for the Viewsonic VX1940W
http://www.ccl-la.com/catalog/product_info.php?products_id=326
Apr 20, 2013 | Computers & Internet
WILL NOT POWER UP UNLESS THE MONITOR IS TIPPED AND MOVED AROUND. WE HAVE TWO OF THESE MONITORS AND THE EXACT SAME PROBLEM IS WITH BOTH, BUT ONE HAS STOPPED WORKING ALTOGETHER. model # VG2230WM
You should open it up and see if it has any loose connections inside, this model is known for having bad caps with bulging/leaking tops and they should be repalced in a set of new caps.
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VG2230WM/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 08, 2011 | ViewSonic VX1940w LCD Monitor
My viewsonic vx1940w monitor won't turn on. There's no lights or anything. The outlet it's plugged into is working because I tried another device in the same outlet. My settings didn't...
I had two ViewSonic's that did the same thing right around 2 year as well. They worked really well for me and then just died.
I found out the first one had a faulty power cord, and the second one just wouldn't turn on at all.
I think there's a good chance that your monitor bit the big one just based on my experience with the brand. I would recommend taking it in to your local computer repair shop and let them take a look at it. If it is 2 years old then it is probably out of the manufacturer's warranty unfortunately. I hope this helps answer your question :(
Thanks for using FixYa.
Aug 27, 2011 | ViewSonic VX1940w LCD Monitor
I have a ViewSonic vx1940w. How do you remove the back to get to the components? The back has no screws or visiable fastners.
There are only 2 screws under the stand plate.
You need to get a small screwdriver and run it around the back plate where it fits into the front surround. It will pop out.
There are several links to manuals if you google the monitor.
I had to replace four electrolytic caps to stop annoying lines scrolling up the screen.
Nov 03, 2010 | ViewSonic VA1912wb Monitor
I have a VX1940w and when I turn it on, the light is dim and it makes a buzzing noise then turns off after about 30s. How can I fix this?
Open it up and look inside for bad capacitors (bulging top/seal) in the power supply, post back what you see inside so we can guide you further, see example of failed Viewsonic monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | ViewSonic VX1940w LCD Monitor
Viewsonic VX1940w monitor comes on for a few seconds then turns off. Press the on/off button and then turn it on again, monitors only stays on for a few seconds then turns off.
vmesa, Do not feel alone! Your monitor's problem same as ten thousand other CCFL back-lit LCD monitors all over planet earth!!!! Yes, and I mean the exact same symptom as you have stated. Yes, it can be fixed, but you shouldn't look to software or drivers to do it. Read my and other monitor guru's FIXYA profiles to find out if you have what it takes to attempt DIY repair on your unit!!! Follow all links you find and visit YOUTUBE!!! After an hour or two of reading you will understand your monitor and what might be the real cause for it's Black or Blank n Black screen symptom and how to fix it. If your pocket is deep enough, then skip all the reading and use VX1940w for trade-in on new unit. 12fixlouie
Bye for now.
Feb 19, 2010 | ViewSonic VX1940w LCD Monitor
How do you detach the viewsonic monitor from the stand?
Hi , if this is possible with that screen , then there should be a clip somewhere on it , that alows it to detach easily, try find the manual it will tell you in there :D
Dec 28, 2009 | ViewSonic VX1940w LCD Monitor
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
ViewSonic VX1940w LCD Monitor Logo
954 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
