Question about Dacor Preference SGM365SS Gas Cooktop
Ignitors clicking happened b4, but eventually went away. I know when I cleaned b4 I had this problem but it seem to go away after it dried out. I thought I kept it dry, but I guess not. These ignitors will not ******* short of unplugging the stove. Will this wear out the ignitors? Will it evewntually go away like b4? Make it stop!!!
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
We have a GE free-standing range top. I spilled water everywhere when my pot overflowed, and the clicking noise will not stop. All burners burn though, what to do?
This is a very common problem when moisture comes in contact with the ignitor. The ignitor sometimes stays in one position causing the clicking sound. it will eventually wear itself out. Best thing to do is try to take it apart, clean it, dry it and adjust it if necessary. If that doesn't work for you, then the ignitor may have to be replaced. Good luck
Jul 11, 2010 | GE Profile JGP636 Gas Cooktop
I have a similar problem with my GE Profile stove
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
Aug 16, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Ignitor sparks continuously
Hi, How long ago did you get the ignitors wet? Most cases, unplug the range for a few hours giving it time to dry out. Maybe set a fan near the range top to help dry it. This helps MOST of the time. please let me know if it helps or if I can assist you further.
Vic
Jul 04, 2009 | Cooktops
Jenn-Aire ccg2523 Natural Gas sealed cooktop. Ignitors on all 5 burners continue firing when I light RF burner. Ignitors will not shut off until I turn off RF burner. Also, how do you access parts on this...
Hi
It seems like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Also you can try to clean it. Please refer to the link and picture: e11b706.gif Please do accept the solution and revert for further assistance. Thanks Rylee
Jul 02, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
I have a GE Gas Cooktop JGP930...we recently started to hear a click from the ignitor. It is only 1-click and it happens periodically... Can be 20 minutes or over an hour. No pattern. What causes this and...
claen the knobs by using a vacium,pull the knob then clean the bottom of the knob area.b4 remove unpug the unit,check how ther position u remove the knob is sane thing to return
tnx gerbee
Jun 29, 2009 | Cooktops
All ignitors work, but right front burner will not light.
gud day,remove the burner base & plate to see the injector (gold color) remove it by using soccet wrench diff.size for diif.brand (common is 7mm) remove it carefuly then u see the small hole very small,clan the hole by using niddle or anyting u want to clean,b4 u back the injector, clean the place wer the injector position by using a vaccium.clean it all if u want but carefuly.unplug & turn of the gas. tnx gerbee gomez
Jan 26, 2009 | Jenn-Air JGD8345 Gas Cooktop
Jennair gas cooktop
Sounds like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Personally I just advise pulling the plug and wait. This is a common issue with gas cooktops and can also happen with liberal use of cleaning products sprayed in the know area.
Jan 06, 2008 | Cooktops
Dacor Preference SGM365SS Gas Cooktop Logo
573 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
