Cobra 2000...D-104 mic..Got a report of radio cracklin..Has good modulation on AM but Poor Modulation On ssb.Factory mic works good on both AM and ssb.The VR11 ssb alc has no affect on the modulation on ssb..
  • Andy Beck May 15, 2010
    Thank for you help..
    Brigadier General:
  • 4,090 Answers
AM is always worse than FM for "crackling noises" try using some WD-40 on your gain pots.
Thanks for using FIXYA
Posted on May 15, 2010
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Why no modulation in transmit mode?
Without seeing it I would guess (and it's only a guess) that maybe you have a broken microphone wire. If it's a factory mic the most common place for it to break is right up from the mic plug. Factory cords are not flexible, their really stiff. We could really use some more information. Mike
Oct 15, 2015 | Uniden Radio Communications
Where can I find a new replacement modulation transformer for a cobra 29 ltd classic?
simple,just chech the input resistance and out put...they should have even small resistance always example .5ohms .3 ohms it counts...
Feb 01, 2014 | Cobra 29 LTD CB Radio
Modulation sounds bassy!!!
first change mic ,maybe the problem are in this mic ,second if the mic is ok verify all capacitors in the modulation near of this ic ,if all are ok change the modulation ic and change it, i hope this help you
Apr 12, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd modulation problen
You need to check the modulation on a modulation meter. Just because the meter doesn't peg, doesn't mean the modulation isn't working. Usally a meter pegging, means the swr's are too high or the meter is misadjusted. If in fact the modulation is low, their is a pot inside the radio (VR4) that will add gain to the modulation circuit. This setting is legally supose to be set by a qualified technician.
Good Luck
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St.
Mills, Wyoming
82644
307-266-4675
wyoed1@aol.com
Nov 24, 2008 | Cobra 29 LTD CB Radio
No Modulation!!
Most modulation problem could be traced to:
1. mic or the cable and/or the mic connector;
2. AMC (amplitude modulation control) - it's a single transistor that regulates modulation and occasionally has been known to clamped on the mic audio;
3. the AM/SSB switch - spraying with contact cleaner is a temporary remedy; and/or
4. audio amp - however if your receive audio is good, then this does not apply.
Hope this be of initial help/idea. Without a model number, I can't be more specific as to component(s) or PCB location but pls post back for any developments (or lack thereof) or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
President mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Jul 31, 2007 | Cobra 19 DX III 40-Channels Base CB Radio
23 people viewed this question
 Grubhead
Grubhead
