Question about HHB CDR850 CD Recorder
HHB CDR-850 Professional loading problem
Perhaps someone can clue me in on a loading problem with this unit. When I load a blank CD into the loading tray and close the door, it will eject the known good CD about three seconds later. I tried various other CD's and made sure it is seated correctly in the tray. I cleaned the laser head and blew it out with canned air. Found nothing jammed in the loading unit. Any help would be appreciated.
Patrick
  • Anonymous Dec 03, 2008
    Mine does the same thing, whether it be ore recorded (commercial) or a blank disk. The drawer opens, then closes again by itself, then opens a second time and displays the message 'CHECK'.
    I really need to know how to sort this probelm out (apart from shelling out another wad for a new CD recorder)
    Problem Solver:
  • 6 Answers
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Posted on Aug 31, 2010
Hhb cdr-882: what mean the letter "i/p"? (On the
That is the INPUT selector button for picking the inputs on the back. The manual for that unit is here: http://www.hhb.co.uk/hhb/global/brochures/CDR882%20User%20Guide%20v1.1.pdf
May 14, 2013 | Audio Players & Recorders
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Mar 05, 2012 | HHB CDR850 CD Recorder
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Aug 07, 2010 | HHB CDR850 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Dec 26, 2008 | HHB CDR850 CD Recorder
HHB-830 CD TRAY does NOT open.
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Feb 28, 2008 | HHB 830 Plus CD Recorder CD Player
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Aug 14, 2007 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
411 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
