Question about Polaris Pb4 - 60 Booster Pump
Will the the pump run if it is connected
Will the the pump run if it is electrically hooked up backwards? Everything seems to be connected properly but the Polaris is not moving. The jet it hooks up to is sucking water when pump is on. Shouldn't it be pushing water?
    President:
  • 1,378 Answers
You can not connect the pump to run 'backwards' since the motor rotation is an internal connection you cannot change. Yes, the port should have water pressure, not a vacuum. Perhaps the wall inlet adapter is installed into the wrong wall port? Did someone change the wall port to allow for a suction side cleaner? Is this a new installation or sudden problem with an old one?
Posted on May 15, 2010
Windshield washer not spraying.
Hi Buck:
Just an idea.....
Is it possible that there are 2 lines on the pump and they are connected backwards?
Also. it is a DC motor so if the wires are recersed it will pump backwards.
Just some ideas.
Cheers.
Jan 14, 2016 | Cars & Trucks
1990 jeep Cherokee won't run but will crank. I hooked my battery up backwards? Everything else in and on my jeep works replaced ignition coil , distributor cap and rotor Any suggestions?
Ign module could be the problem do you have spark when cranking. If you have spark can you hear the fuel pump running while cranking. Let me know
Oct 03, 2015 | Jeep Cars & Trucks
Bandsaw runs backwards
This is some sort of electrical stuff. Please make sure that the wires are connected properly. Check your manual for correct installation of the wires. If this won't work, Check the motor. Turn it around. If it still runs backward, it must be the capacitor.
Mar 11, 2013 | Saws
I have a Balboa 500Z and everything works fine except the two speeds on the pump are backwards. When it is in normal heating mode the pump runs on high insted of low.
Switch the black & red wires, normally these are connected to the speed ports of the motor. But.... be careful! Electricity is color blind and does not care what color wire it is traveling through. So therefore confirm that the black & red wires are on High & Low marked lugs. Then once that is confirmed, then switch the position of those two wires.
Feb 08, 2013 | Balboa Instruments Duplex Digital Panel 2...
I changed the battery on my 07 cobolt... it sparked and now my radio and factory alarm dont work
if you connected the battery properly(red to positive, black to negative) there should be no problem even if the connections arced. if you hooked it up backwards you may have fried all the electrical in the car. does anything electrical work? does the car run?
Aug 21, 2011 | 2007 Chevrolet Cobalt Coupe
My fuel pump does not work while hooked up to the electrical system. Once I hook it up to an outside electrical supply it works. The fuse is OK. Where might the problem be?
check for power at the plug to the fuel pump. No power? check fuel pump relay. check for proper ground connection or make a new ground connection.
Aug 09, 2010 | 1998 Lincoln Town Car
Wires came off capacitor. motor seems to be running backwards
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric motor repair shop for an inspection.
Jul 18, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Replaced the fuel pump fuel filter , no start in my 95 S10 Blazer. add gas will run, untill the gas stops pouring in by hand . new part on top of the throtle body as well, i think it controls th O2 and...
1. Does the pump actually run (key on engine off) pump should run for 2 seconds and go off and can be heard if you listen at the filler neck with the gas cap removed)
pump not running - Check relay (replace if bad) check wiring/fusese
Pump runs... go on to #2...
2. check the gas guage. is the gauge reading in the normal area it would read in or is it way way off like WAY above full or way below empty? This is a sign the electrical connection at the pump is plugged in backwards and the pump is spinning the wrong way and not picking up the fuel... (This is easy to get plugged in backwards inside the tank when installing the new pump)
3. Check for feed, return and vent lines being installed wrong where they attach to the tank... they can easily be hooked up wrong and fuel is either pumped up in to the return line or pumped in to the fuel tank vent line..
4. check for kinked or crushed fuel lines from tank to engine.
5. check fuel pressure regulator to be sure its not stuck open.
Jul 13, 2009 | 1995 Chevrolet Blazer
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Polaris Pb4 - 60 Booster Pump Logo
394 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
